L300 hight beam
Discussion in 'Tech/Mech General' started by Wildbill, Oct 20, 2012.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    cant seem to get high beam on my L300 classic camper will this be on a relay HELP pleas
    :Sad::Sad:
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,778
    6,045
    Mansfield,Notts
    Might help if I knew what a L300 was, Mitsubishi maybe??
    But in any case yes a relay will be in circuit, but it could just as easily be a switch, fuse or cable fault
    Without hands on, all advise will be best guess:RollEyes:
  3. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Little flat nosed van derived, Geo - similar to the toyota lite ace.
    I would say on this age of vehicle, you are probably looking at the stalk switch that has failed
  4. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    yes Mitsubishi the swich on stering wheel ok or stack swich is ok
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    the swich seems ok it is
    Mitsubishi
  6. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,456
    7,297
    Derby
    Happened to me last year - it was the stalk switch (04 Ducato) - after flicking the switch a few times it worked normally.
    I then realised that MHs rarely travel at night, especially in winter and that the contacts on the switch were probably just dirty or corroded through lack of use.
  7. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Have you tested it with a meter? Usually, they wear internally.
    Failing that, look for the relay.
  8. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    ok will do just got a meter other day cheers
    :thumb:
  9. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
