kwikee steps (1 Viewer)
agilityeye
27
Lancaster
8 years
got a kwikee step on the rv but its gone very lazy, only goes in 3/4 of the way, however if you give it a slight push when its going in it goes all the way in fine.
this is fine if your walking away from the rv but if your driving away then the step is sticking out 4inches
any body any ideas on how to sort it out
Ian
X
Xoxoc
Yep, had the very same problem myself.
At the very least, spray all the joints liberally with wd40.
To do it properly, clean off all the crud with a wire brush and then lubricate all the moving parts of the step mechanism.
HTH
Bryan
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Assuming it is clean and lubricated you may have a bent arm or other retriction/obstruction, failing that a tired motor
there is no specific fault to fix
mine started doing just that:Doh: and sorting out as above cured it:thumb:
Geo
Jim
Ringleader
Jul 19, 2007
36,454
131,067
Sutton on Sea, UK
Adria Panel Van.
Since 1988
When you get under there, there is a small terminal that has about 4 wires leading to it. If its like mine its pretty exposed and both times that my steps have played up, cleaning this of crud has fixed it. I now have if it all sealed up with gaffa tape.
Link Removed in our downloads section will probably cover your steps:thumb:
Whenever you are working on your steps, ensure that they are switched off. You would not be the first to lose digits on an RV step, they are vicious.
agilityeye
agilityeye
27
Lancaster
8 years
well spent best part of 2 hours flat on my back.
managed to take off the motor and arm complete with the plate.
left the step on.
took it into the garage and cleaned it up allthough it was very clean anyway.
re greased it all up put it back together and back on rv.
and..........
it still doesnt work:cry:
think it could be even worse than it was before.
so looks like i am after a new step motor assembly
anybody got a spare one floating around???
or any ideas where to get the parts
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
It was the step unit its self not the motor that reqs lubricating
did the step feel loose enough with the motor removed ie did it push in and out ok, slight resistance is all the motor can cope with before it stops
Geo
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Have you down loaded the manual from the download section
It looks then like a tired motor or poor earth /power leads:Doh:
Geo
agilityeye
agilityeye
27
Lancaster
8 years
i would have said a tierd motor
the earth is clean as i removed it today
all the power leads and connectors are clean
will go and look for the manual
agilityeye
agilityeye
27
Lancaster
8 years
downloaded manual and all seems wellwith power and so on
however when i tried a good battery to the motor on its own it did the same
so i think the motor has got a problem.
any other ideas??
where can i get a motor from??
Ian
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Give Duncan a call @ starspangledspanner.co.uk
he's based in lincolnshire will post out anything reqd and will offer work arounds and advise freely if any available
07738 669938
