Kontiki 640L Kitchen sink (1 Viewer)
Rockingdodge
30
Ross on Wye
I need a replacement kitchen sink for my '97 Kontiki 640L. the current one is a tight fit against the fridge. does anyone know of current ones that will fit?
i'm also on the lookout for one for the shower room as well.
Roger
Rockingdodge
Rockingdodge
30
Ross on Wye
Thanks, have been to both of those and quite a few others as well but the ones that have the same overall dimensions, 650 x 400, have too wide a bowl which doesn't fit by the fridge. i have run out of ideas. :Sad:
Mikemoss
177
52
Corsham, Wilts
I have a 1998 Bessie (v similar to your KonTiki I guess) and this is the washroom basin for that. They might just have a kitchen sink as well:
Good luck with it.
Rockingdodge
Rockingdodge
30
Ross on Wye
Good luck with it.
Thanks Mike,
Had already had a look and there are one or two that are close and if I can't find the correct one will investigate closer.
My big priority at present is to find one for the Kitchen as below:
dshague
996
302
VAN CONVERSION
20 years
that looks like a standard caravan sink have you tried caravan breakers .big one in wales i believe ,
try phoning .autocraft 01246471100 for new stuff and knollbeck caravans 01226 753956
caravan surplus knollbeck used to have the bathroom sink in stock but not been in for over a year you never no
32,673
66,650
I assume you've only looked at the websites and not contacted the companies concerned? If so, give them a ring - I know for a fact that O'Leary stock lots and lots of stuff that isn't on their website.
Rockingdodge
Rockingdodge
30
Ross on Wye
Thanks David,
It is a standard type touring caravan sink but it's getting the correct size as there is so little room for the bowl the dimensions mentioned previously are critical but I will ring those two tomorrow.
Regards
Roger
Rockingdodge
Rockingdodge
30
Ross on Wye
I have spoken to O'Leary as I was planning to collect from the Shepton show but he hasn't got the bathroom one and I'm waiting for the sizes of 2 kitchen sinks that are possibilities. I live in hope.
At worst if I can't find one I will have mine fiberglassed at the same tie I have the shower floor coated at Branfibre in a few weeks time.
Regards
Roger
