Keeping the fridge cool in high temps.
Discussion in 'Fridges & Ovens' started by stevebill, Jul 4, 2014.
  1. stevebill
    stevebill Read Only Funster
    Jun 23, 2010
    26
    95
    UK sometimes
    Our 3 way fridge has been really suffering in 30deg+temps. After reading endlessly, I did all the usual things like take the fridge out, turn it upside down for 24 hours, clean the chimney etc etc. it kind of worked, the fridge was running cooler, but not cold. I bought a 120mm 12v computer cooling fan for 10€ in Lisbon a few days ago,and wired it into the outside light switch (which is conveniently close to the extent of the fan wires) and took the outside light bulb out. The fan is positioned behind the grille, and pumps hot air OUT - check with the flat of your hand to see which way it should go. I secured it with a couple of zip ties. 24 hours later, it's working much better, and the fan is silent. I turn it off every night, and flick the switch back on in the morning. I suppose it's a running repair, I will dismantle it and wire the whole thing in properly via a fused switch when we get back to the UK in Sept. Anyway- the fridge now works better than it did when we bought the van, and I will fit a fan even if we end up buying a new fridge, they work so well.
    Incidentally, the fridge is wider than the habitiation door! A fridge swap would be interesting, a bit of swearing would definitely be involved....
  2. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,720
    Lost in La Mancha, Spain
    When we are out in our MH here in Spain we leave our fans it on 247 as even at night the temp can be 21C at 2am.
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,285
    16,958
    Liverpool.
  4. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,088
    2,950
    Essex
    You could try parking with the fridge side of the van in the shade.
    I have also heard of folk taking the external vents out altogether.
    Perhaps the gas jet needs a clean?
    Good luck
  5. Sidney
    Sidney Funster
    Jan 27, 2013
    1,258
    824
    Stamford
    I have a RMD 8555. I put a 2 fan kit into the ventilation space last year and it works well.
    However when in France recently there was a heatwave (38°C) and the fridge was not cold enough whereas the freezer was performing well.
    On my return I bought two fridge thermometers and an internal fan that draws air over the fins to improve performance.
    The thermometers have a screw on the back to adjust them (and were showing different temperature!) so I'm unsure where to put them so I may calibrate/adjust them.
    Any suggestions?
    • Like it Like it x 1
  6. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    Had the same problem with our first van, ended up taking the passenger seat out & removing the fridge through the passenger door.
  7. stevebill
    Jun 23, 2010
    26
    95
    UK sometimes
    I reckon that's going to be the only option! I've had a quick look, and getting an Isri seat out doesn't look easy- there seems to be a circular faster underneath. If I research enough, there will be a way.
  8. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,929
    3,395
    Eastbourne East Sussex
    I have a 5" fan on my top fridge vent. It does help when it's really hot. Our fridge vents are on the awning side so are in the shade which may help too.
    I have a thermometer which is velcroed outside the fridge which has two probes for the fridge and freezer which is useful to check everything is working.
