just got home in our Autotrail to smell Diesel..... (1 Viewer)
sean n maggie
672
327
leeds
autotrail
just got back from a long trip in the van and smelt diesel...looks like we could have a leak nearside as its dripping from just behind the front wheel strut....i have tried to get under to look and looks like there might be a small black fuel filter there,,,,is this leak common on a Autotrail on 08 plate ? it,s going in to garage tomorrow as we need back ASAP.....anyone else had this problem ????
buckby
213
147
nottinghamshire
coachbuilt
fuel filter leaks are common on the fiats probably not been fitted properly should be easy to sort
tonka
10,833
21,531
Cannock, Staffs
A class Burstner 800
Since 2000
Fuel filter - Ducato - leaking - common..
YES... Just do a web search..
Apart from that cant say much else, we had it happen to us just after the van had been serviced..
That was a 2005 model.. They seem to change the filter design every few years..
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
since 2008
Same here. Had the problem twice, both times after Fiat "Professional" allegedly serviced it:(
Have a look on fleabag and you can buy a cage that you can use to tighten up the filter top. The torque setting is amazingly high and to do it without the cage device (as Fiat "professional" seem to do as they shrugged their shoulders when I mentioned it) risks damaging the housing and then you really have a problem. Andy Techno posted a thread about this, I believe
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Swop the hole filter body had a website from Andy (Tecno100)
£59:45 filter included so no need to open it.
I am rubish at finding things back on here but it was a thread of mine Ducato fuel filter.
Mel
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
I can recommend M&J Auto's on Butterley Street just behind Costco. They look after my cars and MH and are spot on. He is too a MH owner and understands its your pride and joy and has changed my fuel filter with no problems at all.
Dave.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Price has gone up again but still only £64.90
Broken Link Removed
Yours being right hand drive should look like this
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
since 2008
Broken Link Removed
That picture fills me with horror......... It just lacks the diesel dribbling everywhere......
sean n maggie
sean n maggie
672
327
leeds
autotrail
Broken Link Removed
Andy is it easy to to change, i have just been quoted £268.00 plus vat for a fuel filter plus fuel filter housing including fitting.....and do you do fitting for a disabled funster......
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes pretty easy
Are you going to order one?
I can fit it for a small fee
I have one spare but I bought at £90
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I have the same problem! Only leaks when I stop at the end of a run.
My buddy Alan (Laneside) has a newer model than mine and it has an all metal filter!
When we get to Pedro's I will find a Fiat garage and see if I can change mine to the newer metal one!!!
Techno
Jul 28, 2010
15,475
20,756
May 2010
Alternatively it may not have been tightened enough. If they didn't cause a fracture it might just need torquing up
sean n maggie
sean n maggie
672
327
leeds
autotrail
Yes pretty easy
just looked at it now its not leaked since i drove home from the garage,,,if i order one can you come fit it sometime please
Techno
Jul 28, 2010
15,475
20,756
May 2010
Nice to meet you today even if only for business (y)
For those following this? we believe that the leaking housing has done about 3k since service before failure.
I checked the torque of the retaining ring and it took about another 1/8th turn before it bottomed out and the torque wrench clicked at 30nm so it will probably be ok to use again.
New unit fitted anyway, primed (this is just a few seconds with ignition on for the pump to refill it) and fired up first go.
So fingers crossed :)
TheBig1
17,630
43,279
due to different electrical connections, the plastic and metal filter are not interchangeable. sadly
personally i have saved the expense and headache, by buying a spare filter and housing. this can be changed at the roadside in 10 minutes. plus i have the correct tool to service the old one which will then be cleaned, new filter and put in a ziplock bag as a spare
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Bugger!!! :crying1:
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I was told that these filters are not interchangeable, by the way, I doubt that it only leaks after the engine is switched off, mine pi**sed out while the engine was running, gradually reduced after switch off due to the fuel pressure reducing. Another Fiat cock up!!
sean n maggie
sean n maggie
672
327
leeds
autotrail
Thanks Andy nice to meet you too, next time we might be able to have a beer together,,,,,thanks for the help,,,,,,,,,,(y)
