Intermittent starting (1 Viewer)
WinnietheBrave
186
17
S. Wales
Since 2008
Why would my fridge fire up on Lpg fine one day, and the next all I get is the x check symbol after the ignition stops?
scotjimland
2,335
10,111
A Woosh bang
Ignition board may be faulty, or have bad connections on the edge connector or just dampness.
Remove edge connector plug and clean connections on board. Remove HT connector and also clean .. then spray board with WD40 or similar to remove dampness... retry
WinnietheBrave
WinnietheBrave
186
17
S. Wales
Since 2008
Excuse my ignorance Jim, but what is an edge connector, and where would I find the Ignition board?
I know where the burner is and there is a black box that the ignitor connects to, but thats about it. :RollEyes:
scotjimland
2,335
10,111
A Woosh bang
If you remove the outside bottom fridge vent it should be visible.. the black box you refer to is probably just a cover for the igniter board.. see if you can remove it, usually held in place by a couple or three self tapping screws.. .. you should then be able to see the board. The edge connector is just a flat plug to connect the wires to the board ..
If in doubt, when you remove the fridge vent cover, post a picture of the gubbins and we'll go from there.. .
WinnietheBrave
WinnietheBrave
186
17
S. Wales
Since 2008
Ok hopefully a picture.
scotjimland
2,335
10,111
A Woosh bang
yeah.. the black box on the left looks like it. :thumb:
