iboost antenna range improvement
Discussion in 'Tech/Mech General' started by Khizzie, Mar 2, 2015.
  1. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,395
    3,662
    Newbury , West Berkshire
    Hi I understand that the I boost pro D8 antenna has been detuned to comply with British and European regulations, if go to a country whose regulations are not so restrictive how can I improve the antenna range.??:whistle:.Roy
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,101
    77,155
    Sutton on Sea
    I'm sure @Addie will see this soon and let you know (y)
    • Like Like x 1
  3. Addie
    Addie Trader - Motorhome Wifi
    Oct 15, 2011
    400
    406
    York
    The restriction is regards to antenna output - this is how loud you can shout. In 90% of cases turning the power up will not make any improvement since the issue will likely be the signal from the source is so poor. If you're trying to pick up an old Linksys B/G router sat behind some campsite reception desk it doesn't matter if you have jodwell bank on your van, it's not going to receive anything.
    If you was outside of the EU, there is one box to untick in the interface which allows you to turn the power slider up. I would never turn it up all the way - since aside from operating illegally you will create a load of noise and interference and actually make things worse.
    The only time where this will make any difference is if you are connecting to a high power installation, with line of sight without any obstructions or local interference (not a campsite with 3 2.4Ghz WiFi devices to every van clambering for the same band). Eg over water to a marina or something similar like that. In that situation you can hear the other side of the link, but it cannot hear you. Therefore if you was outside of Europe you might like to increase the power by 1 or 2 points until you establish a connection. I would always return this back to the legal limit irrespective of which country you are in before moving on.
    In some situations you might actually like to turn the power down if the signal is too good as has happened this winter on a few sites. Just like shouting in someones ear, if you shout to loud you start to distort.
    Apologies for my terrible analogies - but hope that explains it in simple terms for everyone.
    Adam
    • Like Like x 6
  4. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,395
    3,662
    Thanks Adam that makes sense. Very grateful for your input. ...Roy
  5. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
    Good answer Adam, but there is also the heat factor, more power more heat more chance of damaging the unit.
    • Like Like x 1
  6. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,694
    11,831
    Plympton, Devon
    I suspect the differences in power between the settings are measured in tens of mW.
  7. hilldweller
    Dec 5, 2008
    26,903
    25,756
    Macclesfield
    More to the point, if their software allows MAX then we assume their hardware copes with MAX.
    More of a concern is how much microwave power some can pump out, they are power limited in some countries on the grounds of danger to nearby human beings. Having as high powered one inside is not a good move.
  8. Addie
    Oct 15, 2011
    400
    406
    York
    Yes - the unit has a temperature cut out although I've not known one to cut out as in reality its only generating power (and heat) when its transmitting and you will never in practice get anywhere near to the 150MBps the unit is capable off in terms of throughput.
    If you was in the USA WiFi is a free for all on the majority of 2.4Ghz bands and the result is better range but also a lot of noise so the mean reason is to keep the crowded 2.4Ghz band as noise free as possible.
  9. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,793
    Kendal, Cumbria
    I don't think it will turn up far enough to be a danger :).
  10. hilldweller
    Dec 5, 2008
    26,903
    25,756
    Macclesfield
    I'm just generalising but I'm sure I've seen 5000mW advertised on ebay. I would not want that stuck to a window a few feet from my head.
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,793
    Kendal, Cumbria
    At 5W that's in mobile phone or pro walkie-talkie territory but pointless anyway. There's little point in exceeding the power of the transmission you're trying to receive - which will be at a low, legal, level.
    • Like Like x 2
  12. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    The sooner we get Wi-Fi off 2.4GHz the better. Dont suppose iBoost would welcome that though?
  13. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    I'm sure Addie will answer this in more detail, but until the wifi providers change over to the 5GHz band then 2.4GHz is here to stay for the foreseeable future. There is already a 5GHz antenna like the one Addie currently supplies, however there are very few if any wifi providers using it yet. I use 5GHz at home and to be honest distance is not as good as the 2GHz band.
  14. Chris
    Chris Funster Life Member
    May 5, 2010
    16,563
    35,241
    kent
    I have tried translating this thread into Greek, but it's no clearer.
    What does all this stuff mean?
    Is my iboost still ok to use?
    • Like Like x 2
  15. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    The "Greek" bit you don't have to worry about - The GHz bands are about frequency changes and again nothing to worry about and lastly your iBoost will be fine and work forever and a day....(y)
    • Like Like x 1
  16. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    Distance no, more channels yes, less crowded yes, channel bonding yes
  17. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Distance being the key thing, then you can see why my post states that fact.
