hymer stub axle. (2 Viewers)
Jan 27, 2014
2,076
4,514
mid wales
carthago chic i51.
Hi we are searching for a rear left side stub axle for our fiat dicatto hymer b564 2500 cc 1996 diesel
Garage says existing one needs changing yesterday we needed a baring got that now say because baring sheared off !!! (Just after mot not mentioned)
the stub axle is damaged so if any one can help advise we'll be very grateful many thanks mike & jan.
we are near brecon wales .
Portland
923
1,424
Conwy
20 years
The MOT is not a service and not a guarantee of road worthiness, it is a statement that at the time of the test it passed all the set points of examination. If the stub axle has snapped then change it ,if has worn to much to keep the bearing fast then a specialist engineers should be able to reface it.
Beacons
Jan 27, 2014
2,076
4,514
mid wales
carthago chic i51.
Yes thats right we need replacement
thank you .
Dec 5, 2013
317
249
Somerset
I know this is the o/s one but it could be worth giving them a call to see if they have or can get hold of the one you want. The price reduction is great.
FIAT DUCATO STUB AXLE HUB CARRIER FRONT SUSPENSION O/S DRIVERS MOTORHOME
£450.00 £59.99
Stock Level: 1
Broken Link RemovedBroken Link Removed
Product Information
FIAT DUCATO FRONT STUB AXLE , HUB CARRIER
NEW, GENUINE FIAT
FITS FIAT DUCATO , PETROL / DIESEL
1994 - 2006
PART NUMBERS 1330868080 ,1336634080, Broken Link Removed
PLEASE SEND YOUR CHASSI VIN NUMBER TO CHECK
FIAT PRICE £450 N/A
MY PRICE £59.99
WITH FREE UK MAINLAND POSTAGE
Product Code: Broken Link Removed Broken Link Removed Broken Link Removed
Here is the weblink
Mike
Beacons
Jan 27, 2014
2,076
4,514
mid wales
carthago chic i51.
£450.00 £59.99
Stock Level: 1
Product Information
NEW, GENUINE FIAT
1994 - 2006
FIAT PRICE £450 N/A
MY PRICE £59.99
Here is the weblink
Mike
Thank you for your very helpful advice and information we will use the links you have found thank you mike & jan.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My 2004 x244 had an alko extension but not a full chassis and retained the original axle and suspension
Techno
Jul 28, 2010
15,475
20,756
May 2010
I guess you're both inferring that you had full chassis ? rather than extensions
Is there any web based information on those? Alko say they have been involved since 1979 but I can only find info for the AMC which is an x25o full chassis
http://www.al-ko.co.uk/edit/files/downloads/al-ko-amc-brochure.pdf
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
The rapido I referred to had the full Alko with torsion bar suspension as oppposed to the Fiat leaf springs.
JockandRita
11,466
150,290
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Andy,
Our 99 Hymer has an ALKO chassis with tandem axles, torsion bars, etc. The only FIAT parts are the cab and front running gear, and rear wheels and brake assemblies.
Apparently, the rear brake cables used to be available from FIAT agents, but are only available direct from ALKO now, but the brake assemblies are still available from FIAT.
Cheers,
Jock.
