Hymer S820 Goldschmitt self levelling gear has no power? (1 Viewer)
Ian cable
15
Suffolk
Hymer s820
I'm a newbie
New to site, be gentle with us, wow what a wealth of knowledge. We have had Inky since Jan 2016 been fine picked her up at the weekend and there is no power on the self levelling device.
Normally works off the leisure batteries, which were nicely topped up?
Any thoughts greatly received.
Feb 24, 2013
13,087
101,475
Bolsover, Derbyshire
Hymer S800
not long enough
my E + P has needed a full reset a couple of times, pulling the main fuse does it, not sure if this will apply to your system, but worth a try if advice above doesn't sort it
Steve and Denise
5,294
14,093
Spalding LINCS
A Class Carthago
Since 2008
Ours is powered from the vehicle battery there are two fuses one on the engine battery + and one on the pump unit a blade type.
As Canopus said the ignition needs to be on and hand brake applied then check to see if the remote has any lights on you may be on to steep angle for auto try switching to manual
rrusty
258
212
None sold sept 2019
It could be the sensor on the handbrake not speaking to the the levellers, that was the problem with my goldshmitt levellers.
