Hymer S820 engine battery (1 Viewer)
Jun 11, 2011
376
435
Somerset
hymer s820
Has anyone replaced a Hymer S820 engine battery. Is it necessary to turn off the leisure batteries before disconnecting the engine battery ? It looks very difficult, and I wondered if anyone has any tips for me please.
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
Hi, i would think that there would be no issue removing the engine battery withoit touching the liesure battery. Some basic saftey will ensure you have no issues.
Make sure the is no potential charging supply to the van.. i.e. mains connection. Remove the terminals from the engine battery one at a time and i would insulate the ends (tape or rubber glove etc ). Then tie them out of the way.
Then carry out the change. Reconnect new engine battery earth first.
scotjimland
2,327
10,081
A Woosh bang
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Has anyone replaced a Hymer S820 engine battery. It looks very difficult, and I wondered if anyone has any tips for me please.
Not had a Hymer but had a Burstner A-class that appeared to have been built around the engine battery with no thought of replacement! Is that what you mean by it looking very difficult? Various bits (technical term) in the engine compartment had to be removed to gain access to it.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you dont have the codes you could short across the split charge relay to keep current flowing to radios but keep loose poitive leads away from chassis
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I had mine replaced (B630, Sprinter-based and not much room in the engine bay) a few years back. I called out the Comfort Insurance home start (RAC I think). I could not have lifted the battery in and out.
I think you should pull the 30 amp fuse that should be next to the starter battery. That will disconnect it from the Elektrobloc before disconnecting the leads (as Jim has advised earlier).
s20hymer
Jun 11, 2011
376
435
Somerset
hymer s820
hya god this is an old post ..bought a new battery at m/b dealers in Albir ....have to kneel in front of bonnet... undo all neg wires to battery and tape up then posy wires and tape then undo aircon wires remove radiator cap... stand battery on end and lift out struggle as it is heavy .... the new one slides in so easy as no lifting reconnect ..and bobs your uncle ...about a mornings work and didn't disconnect leisure batterys
s20hymer
Jun 11, 2011
376
435
Somerset
hymer s820
thats one of the things you remember doing as the skin grows back on knuckles ...had a new engine since then... totally different story
