Hymer B544 Headlights. (1 Viewer)
jumar
3,779
11,625
Spain
Hymer Tramp
Since 1994
Hi, got some friends from the UK visiting us in Spain next week, they have asked me the following question which I am unable to answer.
Hymer B544 LHD but now used in UK, headlights are UK Spec. and satisify MOT standards, is it required to fit converters to drive on right here in Spain and how do you do it with those little round Hymer type lights.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
If the headlamps have been rotated in their mountings for LH driving (UK) your friends will need to fit beam benders to be compliant with French and Spanish regulations. (I am assuming we are talking about Hymer B-class from around the end of the 90s until 2005 with twin headlight units - see picture below).
As the dipped unit is of the projector type, they must use the semi transparent 'Eurolites' beam benders not solid tape, or worse, silver-backed masks as this will cause over-heating.
The Eurolites package contains fitting instructions, but in case of doubt, use the circular piece and locate it as shown in the other picture below.
p.s. The dipping headlight unit is the outer one of each pair
872
3,361
Leyland Lancs
since 2001
All the beambenders I have looked at for my 2004 Hymer have been larger than the headlight itself.
Although I have never attempted it, three screws, behind each light assembly, if loosened, allow the assembly to be rotated for either UK or Continental driving? So I am informed.
JeanLuc
3,304
2,199
Warwickshire
It's true that the Eurolite circular section is a bit large: I allow it to overlap the edge of the glass slightly at the top right. Alternatively, you could cut a bit off the mask with scissors.
Regarding the 'screw loosening and swivelling' option: I have tried to do this on several occasions and given up each time - it's an absolute b**tard to get in there and see what you are doing. I have even tried taking photos and I have had the front bumper/skirt off in order to get better access. I think at least one of the screws is located behind the beam levelling device. A couple of months ago I was with Peter Hambilton having some work done and I asked him about the conversion he does to fit larger screws enabling the headlights to be loosened more easily. He said 'more easily' was a relative term and that even then, it was not a simple job without undergoing significant contortion.
I'm sticking to Eurloite beam benders (which I save and re-use several times - fixing them with small strips of clear waterproof sellotape if required).
