Hymer B534 Truma Boiler Seized Up (1 Viewer)
Queenie
50
7
Cornwall, United Kingdom
Motorhome truma heater is not working properly, as i haven't used the boiler for hot water for 2 years, i tried to heat water and nothing comes out of hot tap, its spitting brown drops of water, the cold tap works ok, so does the blow air heating......i think there maybe a blockage, i tried to suck the air out the tap but nothing works? Also the green light on the switch by the wardrobe will not go on? Checked fuses, got full gas, only works on 12v turned on and off lots of times, fans on the boiler are noisy maybe need changing? I am at a loss, in Cornwall, think i might have to put into workshop.....any other ideas from anyone before i spend a fortune....:(
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Have you also opened the shower and hand basin taps as the air must be out of all of them before it will work properly.
wasp
1,724
18,180
Warsop
None gone caravannin
If it is an Ultrastore the immersion heater may be blown they like house ones they wear out with clean water constantly washing over them, also is the water pump working
Queenie
Queenie
50
7
The hot air works, the pump works. Thanks all looks like ill be checking into a workshop soon.....
JockandRita
11,462
150,187
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Open the dump valve, and view both the flow and the colour of the water coming out.
If no water flow, then hot water tank is not primed. Close valve and start again.
If water is brown (as you described from the tap), try flushing through. I am assuming you have the Truma Trumatic C system.
Good luck with it,
Jock. :)
Queenie
Queenie
50
7
The water is clear on the cold tap....just a splattering of brown on the hot tap, so if i dump how will that help, the hot water tap in bathroom also has no flow but ok with the cold?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I would talk to LeisureshopDirect. They sell replacement water containers for the Truma C3402/6002 range (assuming that is what you have). It might be possible to replace the damaged part rather than buy a new unit which will be a different model as the C series is no longer made.
Queenie
Queenie
50
7
Yes its the C3402 i found out today that it is no longer made....ive been trawling the net for a boiler, so expensive, i wouldn't know what part doesn't work, so I'm going to flush the water system tomorrow again and see what happens, if nothing will have to have a good think on what to do, thanks for the info ill get in touch with the leisure shop.
sdc77
3,244
4,550
Weardale, Co Durham
My suggestion is...
Familiarise yourself with the boiler then once you know how it all works and is not working... Make sure you're on hook up.. Have gas on.. Water in your water supply and call truma technical on 01283 586020.. They are quite helpful... But in Derby so a bit far for you
Queenie
Queenie
50
7
Already done that and they say i need new boiler.....anyways been messing about this morning and now i have no blow air heating.....if i decide to sell the van should i get it fixed or sell as it is, thats the question? Thanks all for your comments....
JockandRita
11,462
150,187
Lincs/Cambs border
N+B Flair 8000i
Hooray hot water now sorted, don't need a new boiler.......so happy :)
Awwwwww, come on Queenie, don't leve it like that. What was the cause of the boiler not working properly, and the lack of hot water?
It'll help those of us with the same ageing Truma systems, should we experience the same faults. (y)
Cheers for now,
Jock. :)
Aug 15, 2014
2,580
3,462
Exiled in Yorkshire
Pilote 600L
Pleased it has been rectified but also would appreciate knowing what the cause was, even if it was finger trouble (y)
Norman.
Queenie
Queenie
50
7
Seemed like the boiler is working perfectly, it took 2 weeks keep turning the hot water tap on to get the water to come through, once it did, i was able to heat water and hey presto...all is working....gather the engineer who came to see it just wanted me to pay out for a new boiler. So the moral of this story is keep trying.....
