Huawei mifi (1 Viewer)
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I'm looking at mifi boxes for our trip to France. Has anyone an opinion on the Huawei E586. I know its an older unit but is anyone using one and is it any inferior to the E5220/E5330 that I see being offered?
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I still use the older one when away in the MH, works perfect though I cant say about abroad as we haven't been yet. :(
Clewsy
118
178
Norwich
Frankia 7900 Platin
since June 2014
Used a 586 for a few years always found it reliable but occasionally could not find a network. Bought a Netgear 763 and plug in additional arial a couple of months ago and it gets a better signal than the Huawei in marginal areas. Have kept the 586 as a spare / back up.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I assume with any of these mifi devices I just buy a 3 data sim and plug it in. Do I need to register it or anything? And using it in France doesn't need anything special doing. I'm not familiar with this stuff at all.
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
Having the ability to plug in an external aerial is a bonus, my mifi gets a much better signal with one but I am not sure the E586 has this feature.
You have to configure the device by setting the correct APN for the network. The instructions should explain this and the 3 website should tell you what address to use.
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Is the mifi locked to anyone. If 3 then fine and will work in France as if you are in UK.
With a 3 sim you insert the sim then go onto 3 and set up a My3 account which is tied to the sim. You when can see roughly how much data you have used / have left. You usre the My3 account to add more data when you re running out.
Remember you need a Mobile Broadband Sim not a phone sim that has Data on it.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I've been offered a used E586 at a good price so don't think there will be any instructions with it. I've got a 3 data sim from Argos (half price there). Hopefully the seller will be able to tell me what hoops to jump through. Do data sims have a mobile/device number?
I don't think the E586 has an external antenna port. But I've read on here that putting it in a sealed plastic bag and putting it on a flag pole (fishing rod) can get me more signal!! A recent thread I think.Not sure if I want to go to that extent.
Vinomog
9
4
Europe for now
Bimobil
Since Aug 2011
The 586E does indeed have an antenna port. I'm sitting looking at it at this moment and I've been using it attached to an external aerial.
Clewsy
118
178
Norwich
Frankia 7900 Platin
since June 2014
Where is the antenna port - I can't find one my E586 - mine is approx. 3 years old so they may have upgraded them since then.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I have just bought said E586. There looks to be a minute connector in one corner under the battery. How you get a cable there is anyones guess. If it is a very low profile 90 degree connector and some modification of the "bodywork" is done then it looks like an external antenna can be added. Not as practical as a connector on the side though.
scotty1
254
38
Kent
Wildax solaris xl
I have used e586 for last couple of yrs in uk no prob, but i got a couple of 3 data sims to take to france last wk and couldnt get them to work,even though i had good 3 signal.
TheBig1
17,630
43,314
dont forget the sim must be live in the uk for at least 2 full weeks before taking it to france etc
scotty1
254
38
Kent
Wildax solaris xl
So if you have 1 month sim you only get to use your 1 gig allowance for 2 wks in france if you time it right? Cheers Scotty
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Back to op Q we have the E586 (unlocked) works perfectly well UK France Spain Portugal Germany Clogland Belgium can't say about other locations (y)
You may have to go into IP address 192.168.1.1 (from memory) password admin admin and tick the roaming box for it to work outside UK .long time ago when I did it
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I've activated the sim so 30 days has started. France in just over two weeks. I thought the sim could be used straight away as it is PAYG not contract. Not an issue for us as we leave two weeks this coming Monday. Do I need to set it for roaming.?
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Yes
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
How is that done?
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
With a 3 sim in the unit and on wifi (from it) or tethered via USB go into you my three dashboard or Google huawei E586 admin admin and look for links to it .when in dashboard full info there when signed in .look for roaming box and tick it .simples
DJA
Mar 5, 2011
661
1,014
A
Since 2008
I too thought that if you take out a new monthly contract with 3 you have to have it working in the UK for 30 days before it will start to work in France as part of the Feel at Home Scheme they offer. However I understood that a PAYGO sim which lasts for a month or a particular quantity of data should work there straight away.
It could be that the Dongle or Wifi you have is old enough to not have European use switched on. I have had a 3 Dongle for years, but never used it abroad, and have just uprated the data allowance and received a WIFI. They advised me that the My3 account I have. which will have the new data allowance triggered shortly. is already set to allow overseas use.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
Hmmmm....just been over every page in the dashboard. I don't see a roaming box anywhere. I accessed via my tablet and the simple page that came up showed the roaming status as "not roaming". But in the detailed pages there is no reference to roaming. Guess I'll need to speak to 3.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
Maybe I'm just interpreting things wrongly. I've registered onto My3 and it tells me that i am enabled for UK and abroad. The Status page on the dashboard shows the roaming status as "not roaming" which I am now assuming means that I am not abroad. It is a status rather than a setting. Still found no other reference on the dashboard tp roaming though.
I spoke to 3 a couple of days ago and they were very helpful- but that was a local store not their support unit (assuming they have one).
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
OK try this using the WiFi or USB on you PC from you mifi .
Go into google type in 192.168.1.1.
Which should take you right into your mifi you will need the password .admin once into mifi the roaming tick box is there .
Best of luck visiting 3 shop. ;)
DJA
Mar 5, 2011
661
1,014
A
Since 2008
I have just been onto the 3 Support and have to say he was very helpful. Tel No 0333 300 050 I pressed 2 then 2 again when asked. You will need the Mobile phone number of your sim card as I also had to type that in twice. The number is at the top of the Bill page on your My3 account. You also may need the IEMI Number which on my E5330 is under the battery..
Good luck
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Mine sits in its stand on the bottom of which says 5v 1amp
