Huawei E5577 start up and set up (1 Viewer)
Baileysbus
731
2,414
Fife
Start of 2016
As per usual I'm late in the day trying to get the mifi set up before our trip away next week. So this is an unlocked device bought from motorhome wifi and I'm following the instructions as best I can.
SIM card is installed correctly; I hit the power button then get the Huawei splash screen and then a battery symbol with 4 bars on it ( which to me suggests it's charged ). That's as far as it gets ....... nothing further than the battery screen.
Anyone got any thoughts as to what's wrong......or more likely, what I've done wrong!
Bob
mikebeaches
5,394
8,601
Bristol
Rapido V68 Van Conversion
Since 2009
If it's anything like mine, you need some patience for it to 'boot-up' and show the mobile signal. Sometimes seems to take like half a lifetime, especially the first time you fire it up, or move to a different country.
The only other thing I can think of is to double check if the sim is the right way up/round.
Good luck with it.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
It will also show "No signal" when it first boots up, which will elicit a groan from you.
Be patient for a while and the signal should come on.......usually very strong.
Richard.
Baileysbus
Baileysbus
731
2,414
Fife
Start of 2016
Good luck with it.
Thanks @mikebeaches. The sim is definitely the right way up. To be fair, we're not in a great reception area here at the moment so that's not going to help either. I shall try and be patient and see what happens.
Jan 10, 2011
75
20
South Coast
Frankia i800 A Class
Mine is a slightly different model, but the battery symbol comes up and then I have to press the start button again for it to start properly. Even in a weak signal area you should get a no signal message.
Aug 18, 2014
23,782
133,652
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I try logging in to something on google which will then make it swop to the Huewei page showing the "connect" graph & bars. click on connect & wait until it does.
Jul 13, 2008
3,739
3,862
Low profile
If it's just showing battery it's not turned on? Maybe. :)
Baileysbus
Baileysbus
731
2,414
Fife
Start of 2016
Ah ha! Thanks @HobbyHarvey ...... that worked (y) Straight in as expected! Many thanks everyone :merci:
