how wide is your gas locker door? (2 Viewers)
lebesset
760
I keep reading about people having british made motorhomes which will only take 6/7Kg bottles
I presume there is a reason for this , but am curious as to exactly how big the doorway is
....I am aware that they must buy in the doorways , but exactly how wide a bottle will pass ...are they all the same ?
as the 6/7Kg bottles are about 500mm high I know that must pass ok
2,337
10,145
No idea on locker door sizes, but I would say it's because it's more convenient to have 2 x 6kg/7kg bottles than one or even two 13kg
For information :
Bottle sizes
Cylinder Type Height / Diameter
Butane: 4.5kg 340mm 240mm
Butane: 7kg 495mm 256mm
Butane: 15kg 580mm 318mm
Propane: 3.9kg 340mm 240mm
Propane: 6kg 495mm 256mm
Propane: 13kg 580mm 315mm
Another often asked question, can I exchange one type / size for another..
Calor Information
Cylinders fall into two categories (see below), and may (subject to availability) be able to be exchanged for another cylinder within the same category free of charge.
To exchange a cylinder for one in a different category, a charge may be applicable.
Category A:
Butane: 4.5kg, 6kg BBQ, 12kg, 13kg, 15kg
Propane: 3.9kg, 5kg Patio, 11kg, 13kg, 13kg Patio, 19kg, 47kg
12kg, 18kg and 46kg automotive / Liquid offtake cylinders
Category B:
Butane: 7kg
Propane: 6kg
L
lebesset
760
thanks jim , but the bottle sizes are a matter of record , it's the size of the aperture that I want to know!
May 22, 2008
484
It's not really the door size that restrict the bottle size you can accommodate but the size of the locker . I can get two 13 kg Calor bottles in my Hymer locker :thumb::thumb:
May 22, 2008
484
I would also guess that Motorhome builders also make the gas lockers smaller because of PAYLOAD concerns as full gas bottles are heavy and so they force you to use smaller ones .:Eeek::Eeek:
Mar 26, 2009
8,163
11,222
Yr Wyddgrug
Hymer B678DL
Measured the gas locker door on my Startspirit which can accomodate 2* 6/7kg bottles:
Width 45 cms & height 51.5
Hope this helps
Phil
L
lebesset
760
perhaps I should have been clearer :Doh:
it's the entry size on BRITISH made motorhomes that I want to know folks , the ones where people say they can only get in the 6/7 Kg bottles
KenandSue
39
West London
Less than 1
Sorry don't know the size of the locker door on our Auto-trail, but we can get 2 x 13kg bottles in.
May 22, 2008
484
42 cms X 52 cms on my friends STARQUEST Motorhome,just measured it and he has just this minute run out of gas, two 6-7 kgs only, hopeless. :cry::cry:
L
lebesset
760
thanks phil and malc , exactly what I wanted to know ...any more offers anyone ? are there other widths on other british motorhomes ?
frankly , that makes the british locker sizes even more incomprehensible to me ; what is the point of making the locker over 400mm wide when the biggest bottle you can fit in is 256mm ?
the point of my question will become clearer later when I have the maximum of information::bigsmile:
43,332
49,500
could be a number of reasons but i reckon the main one is cost...a small door for 9kg bottles may be £30 but a larger one for 13kg bottles may be as much as £50.
and why fit a large one when theres only locker room for 1 x 13kg and 1 x 9kg ?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi ,when i built mine i used a 380wth 800mm high door .can get 2 19kg bottles 2 camping gas and lots of other bits and pieces in the locker. cheers alan.
Phil
226
Herts
10 years
My locker takes a 15kg bottle.
The door aperture is 560 x 330 and the inside is 710 h x 370 w x 370 d.
The compartment is fully lined with galavanised steel sheet.
Access to turn the gas On or Off is from inside the van where there is a type of 'Port Hole' with a large screw-in sealing cover.
Phil.
L
lebesset
760
thanks to all for your responses
sounds like a bottle 300mm in diameter and 500mm high would fit in most vehicles at least
