How to make Vista and Windows7 faster (2 Viewers)
2,338
10,132
Saw this tip on an other thread, thanks Wivvy's dad , and thought it worthy of a fresh post .. it's from another forum so I've copy pasted verbatim.....
Did you know that by default windows 7 and vista don't use all your Cores. What I mean is they don't use the dual core system that you payed $700 for or the 2G you put into a quad core and most of the time your only using one. Well here is a tutorial to change that!
First you need to click the start menu button
Now type in msconfig in the Search Program and Files Search bar, and press Enter, or click on the msconfig button.
Now an msconfig dialog box will pop up and then click on the boot Tab
and you will see this.
Now Left click the Advanced options... button and you will see something like this:
Check the box next to Number of processors: then Left click the arrow thats on the right of the 1 and select either 2 or 4 cores. depends on what you have for a system I have quad so I am going to go all the way to 4. Like this:
Click OK and apply.. A re boot is required to apply settings ..
Pat4Neil
1,247
494
Mercedes
7 years
Great tip.
Another good tip is to have a look at the start up list in MSCONFIG. This shows a list of programs that your computer activates during its start up and then runs them in the background, slowing everything down.
You will probably see names of prgrams you rarely use, by unchecking these and rebooting it all goes abit faster.
However, be careful some of the programs ( Usually at the top of the list ) are operating ones so only un check the ones you can identify.
If you do un check an essential one then its no great problem you simply go back into MSCONFIG and re check it then reboot.
Hope this helps
Neil
moandick
1,312
112
Landrake, Cornwall
Euro-shed
Yes, thanks ScotJim. I am usually very shy of touching anything technical simply because I do not generally know what I am doing - and prefer to leave it to the experts. However in this case - a picture is really worth a thousand words so I did it and it seems to have worked.
Maybe one small dumb question, though.
I have a Dell Inspiron - on the front of the box it says "Core 2 - quad"
Now I took that to mean 4 processors (quad) and therefore set that figure in the box. As I said - all appears to be working and maybe a bit faster - BUT from the previous paragraph - should I have set the computer as a dual processor (Core 2) or as a quad processor - or does it not really matter?
I presume being as it was originally set to one processor - that it will only use whatever processors are available?
Dick
2,338
10,132
Dick
Hi Dick
In the setup it will only show the number of cores available, in my case it showed 2 , no option to select more , so yours must be 2 x dual core processors ... selecting four would be correct .. is that what you meant ?
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Thanks ScotJim.
I wasn't able - at work - to copy that out, which is why I posted the link, little realising that it needed signing up to the site in order to view it.
A good tip though, it's nice to have 4 cylinders working instead of 1, when all 4 should be up and running.
G4GMO
444
15
Herefordshire
Checked my dual core useage
Thanks for that useful information Jim. Had never considered that the operating system might not be utilising both cores. As I am running Linux it meant finding how to check under Linux, if anyone is using Linux Mint/Ubuntu, then open a terminal and type top return in the terminal then 1. It will show cpu0 and cpu1 in the third and fourth lines of text in the terminal window.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Got 3/4 of the way through was struggling with finding the same panes as shown in the pics before I realised I aint got Vista or 7 on this pooter:Doh:
Any tips for making mechanics faster, apart from paying them more:RollEyes:
2,338
10,132
Used to work for me ... just whisper 'job and knock' in their lug hole ... or ' piece work rate ' :roflmto:
wivvy's dad
3,205
1,795
48.066895,12.862673
May I assume you have XP?
If so,
press START button
type msconfig in the RUN box
click BOOT.INI tab
click ADVANCED OPTIONS tab
in drop down box to right of /NUMPROC click the drop down arrow
change number from 1 to whatever max you are offered i.e., 2 or 4
click all the OK's to exit and re-boot
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks very much wivvy's dad and Jim.
We've applied the change on two XP machines and a Vista laptop and it certainly does the job. Very strange that the default isn't to make full use of the processing power - or at least give the option in initial set-up.
As far as mechanics go the only way to produce acceleration is to use Newton's second law of motion and apply a force to the mass - a ruddy great boot up the ar*e :ROFLMAO::ROFLMAO:
Graham
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Yep, thanks from me too. Mind you on my new lappie it has the i7 processor, in system information it shows as quad core, but 8 are available when I go into msconfig???:Smile:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
If so,
press START button
click BOOT.INI tab
Well what a disapointment
Offered 1 or Sod off:Doh:
When I bought it 18 years ago they said it was top of the range:Doh:
Thank for the tip Mr Wivvy:thumb:
Will have a play wiv me windows 7 machine to night Jim:thumb:
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
It might be getting confused - the i7 uses hyperthreading (like in the old Pentium 4) to make 4 processors look like 8.
43,331
49,480
same mistake here geo :Doh:
If so,
press START button
click BOOT.INI tab
tried that and the tight buggers have only installed one core in my lappy :cry:
but it is about 5 years old. ::bigsmile:
Tommy_harry
184
28
County Durham
c class
2 days
Another tip to speed up your pc is to run 'startuplite' a program from malwarebytes - it checks all of the programmes that auto-start on your pc and advises which ones you actually need....
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Seemed great but found my desktop does not like it. Kept getting "blue screen" then the thing would shut down. :Angry: Put it back to 1 core and all seems ok now. :thumb:
wivvy's dad
3,205
1,795
48.066895,12.862673
That sounds more like a power supply unable to handle the extra BHP. Try a bigger power supply.
GJH
29,450
38,827
None, now sold
2006 to 2022
Natural Scots tendency to save the bawbees if it looks like too much of that new-fangled electricity is being used? ::bigsmile:
JockandRita
11,462
150,165
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
:ROFLMAO::ROFLMAO::ROFLMAO:
The MH XP lappy only has one processor, so no speed upgrade there, but the new Windows 7 lappy will get a tweak when I get home.
Thanks to Jim and Wivvy's Dad for the info.
Cheers,
Jock.
