How to Jack up a tag axle van? (2 Viewers)
makems
3,440
27,702
Ingleby Barwick,,Teesside
Sadly had to give up
I have a slow leak on the rear offside trailing tyre and will take it to a tyre repairer.
How should the rear be jacked up to remove the wheel?
I am concerned that the repairer may not know how to do this properly and I want to know so I can watch him and make sure its done correctly.
Phillybarbour
270
216
West Lancs
Globecar Campscout Revo.
Use the jacking point only and not on the chassis rail elsewhere. The jacking point is normally the area painted black close the the suspension parts.
Jan 2, 2015
2,472
8,630
Cumbria
Burstner Solano t725
since 2014
I can't remember what they are called but there is a gadget a bit like a levelling ramp with a 'dip' in it designed for tag axle trailers that you drive the 'good' wheel onto thus raising the 'bad' one of the ground for removal. Not sure how safe they are or how it affects the weight on the 'good' axle.
Just found them....
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
Had the bad luck to have 2 rear punctures on my tag in 5 years ownership.
Both times changed by me on the roadside just Jack under the axle you need but do remember to chock the front wheels first.
Simples:)(y)
Badknee
7,408
412,861
notloB
Vantage Neo
Living the dream.
It may involve crawling underneath to have a look but you want to lift up the wheel only not the whole Moho so as FB says lift the axle or sometimes if your using a trolley jack you can get good purchase under the bottom of the shock absorber.(y)
Chris
21,056
278,886
10 years
This looks the easiest and safest way(y)
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Just found them....
Seems expensive, use of milenco ramps could do the same thing.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Take plenty of Vasteline with you for when he tells you were to shove it
as you teach him to suck eggs,
Reactions: JJ
Nov 2, 2008
461
377
PVC, S&L Iveco
45 years
You know how and I know how but I have met a number of tyre fitters who didn't have a clue and needed guidance, always best to use the man who pays the bills.
Oct 29, 2008
5,070
5,973
West Yorkshire
Jacking points are easily identified if you look underneath
Dec 12, 2010
5,414
21,587
Cumbria
Tyre fitters local to us think that when the torque wrench "clicks", that's the signal to really start pulling on it :eek:
makems
makems
3,440
27,702
As long as he does it the way described above I wont have to say a word. However my fear is I end up with some numpty who has never seen a tag axle van before.
Badknee
7,408
412,861
notloB
Vantage Neo
Living the dream.
Unless I'm doing work on the suspension I never use the jacking point and just lift the wheel up enough to remove it. (y)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Simples:)(y)
NEVER jack an AlKo setup under the axle itself, you can cause irreparable and expensive damage that way! There are cast steel jacking points fitted at the chassis just in front of each axle usually, jack under these.
D.
Forestboy
5,023
8,338
Forest of Dean
D.
Sorry Dave you're right my answer was a bit vague re reading it, those are the jacking points I've used both times.
Don't suppose you could answer my question on another thread about re gassing a roof mounted Dometic aircon unit, is it possible or is it a specialist job ie different to re gassing cab aircon.
Cheers(y)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Cheers(y)
Sorry FB, I don't deal with AC units at all, ask EddieVanbitz, they're dealers for Dometic Waeco or Waeco Dometic, whichever way round they prefer to be called this week ;-)
D.
makems
makems
3,440
27,702
D.
Thanks Dave. I will have a look so I know where they are and make sure the repairer uses the correct point.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
As an aside, how did the fridge mods work in Morrocco? Feel free to answer via PM if you want rather than dilute this thread.
D.
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
I have the same m/home as you
If you look between the two rear wheels you can see the black suspension bracket, on the bottom face is a round boss. This is where the useless fiat jack locates, I use a 5T hydraulic jack when I have to (3 punctures in 2 years)
