How to Jack up a tag axle van?
Discussion in 'Tech/Mech General' started by makems, Jul 20, 2016.
  1. makems
    makems Funster Life Member
    Sep 23, 2011
    2,687
    10,939
    Ingleby Barwick,,Teesside
    I have a slow leak on the rear offside trailing tyre and will take it to a tyre repairer.
    How should the rear be jacked up to remove the wheel?
    I am concerned that the repairer may not know how to do this properly and I want to know so I can watch him and make sure its done correctly.
  2. Phillybarbour
    Phillybarbour Read Only Funster
    Feb 2, 2013
    192
    142
    West Lancs
    Use the jacking point only and not on the chassis rail elsewhere. The jacking point is normally the area painted black close the the suspension parts.
    • Thanks Thanks x 1
  3. namwaldog
    namwaldog Funster
    Jan 2, 2015
    470
    778
    Cumbria
    I can't remember what they are called but there is a gadget a bit like a levelling ramp with a 'dip' in it designed for tag axle trailers that you drive the 'good' wheel onto thus raising the 'bad' one of the ground for removal. Not sure how safe they are or how it affects the weight on the 'good' axle.
    Just found them....
    http://www.barlowtrailers.co.uk/Trailer_Aid_Ramp_Yellow_B0055
  4. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,088
    8,178
    Forest of Dean
    Had the bad luck to have 2 rear punctures on my tag in 5 years ownership.
    Both times changed by me on the roadside just Jack under the axle you need but do remember to chock the front wheels first.
    Simples:)(y)
    • Thanks Thanks x 1
    • Useful Useful x 1
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,745
    16,489
    notloB
    It may involve crawling underneath to have a look but you want to lift up the wheel only not the whole Moho so as FB says lift the axle or sometimes if your using a trolley jack you can get good purchase under the bottom of the shock absorber.(y)
    • Thanks Thanks x 1
  6. Chris
    Chris Funster Life Member
    May 5, 2010
    16,642
    36,126
    kent
    This looks the easiest and safest way(y)
    • Funny Funny x 7
  7. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,138
    3,737
    Scotland
    Seems expensive, use of milenco ramps could do the same thing.
  8. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,740
    5,967
    Mansfield,Notts
    Take plenty of Vasteline with you for when he tells you were to shove it
    as you teach him to suck eggs,
    • Funny Funny x 2
    • Like Like x 1
  9. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    E&P hydraulics (y)
    • Like Like x 2
  10. Ranger
    Ranger Funster
    Nov 2, 2008
    234
    196
    Lincolnshire
    You know how and I know how but I have met a number of tyre fitters who didn't have a clue and needed guidance, always best to use the man who pays the bills.
    • Like Like x 1
  11. Techno
    Jul 28, 2010
    14,140
    15,091
    Yes lots of professional producers of cow dung about for sure
    • Like Like x 1
  12. jezport
    jezport Funster
    Oct 29, 2008
    1,836
    1,241
    West Yorkshire
    Jacking points are easily identified if you look underneath
    • Thanks Thanks x 1
  13. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,692
    3,275
    Cumbria
    Tyre fitters local to us think that when the torque wrench "clicks", that's the signal to really start pulling on it :eek:
    • Like Like x 1
    • Funny Funny x 1
  14. makems
    Sep 23, 2011
    2,687
    10,939
    As long as he does it the way described above I wont have to say a word. However my fear is I end up with some numpty who has never seen a tag axle van before.
    • Useful Useful x 1
  15. Badknee
    Badknee Funster
    Aug 25, 2014
    3,745
    16,489
    notloB
    Unless I'm doing work on the suspension I never use the jacking point and just lift the wheel up enough to remove it. (y)
  16. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,577
    3,379
    Telford, Shropshire
    NEVER jack an AlKo setup under the axle itself, you can cause irreparable and expensive damage that way! There are cast steel jacking points fitted at the chassis just in front of each axle usually, jack under these.
    D.
    • Like Like x 2
    • Thanks Thanks x 1
    • Informative Informative x 1
  17. Forestboy
    Jul 31, 2007
    5,088
    8,178
    Forest of Dean
    Sorry Dave you're right my answer was a bit vague re reading it, those are the jacking points I've used both times.
    Don't suppose you could answer my question on another thread about re gassing a roof mounted Dometic aircon unit, is it possible or is it a specialist job ie different to re gassing cab aircon.
    Cheers(y)
  18. dave newell lvs
    Oct 31, 2008
    2,577
    3,379
    Telford, Shropshire
    Sorry FB, I don't deal with AC units at all, ask EddieVanbitz, they're dealers for Dometic Waeco or Waeco Dometic, whichever way round they prefer to be called this week ;-)
    D.
    • Like Like x 1
  19. makems
    Sep 23, 2011
    2,687
    10,939
    Thanks Dave. I will have a look so I know where they are and make sure the repairer uses the correct point.
  20. dave newell lvs
    Oct 31, 2008
    2,577
    3,379
    Telford, Shropshire
    As an aside, how did the fridge mods work in Morrocco? Feel free to answer via PM if you want rather than dilute this thread.
    D.
