How to check for damp? (1 Viewer)
michael morris
5
Worcester
Don't own one yet
I'm a newbie
We're looking for our first motorohome. Because we are on a somewhat limited budget, we'll be looking for a C Class around 20 years old. All the advice we have so far (very gratefully received) keeps re-iterating the need to thoroughly check for damp. Is there a guide on how to do this?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Most often the damp issues will be around the bottom corners of windows and rear corners. Make sure you lift the cusions check the lockers for musty/mushroomy smell, discoloured wood or decoration. Get a moisture tester, 2 prong affair off ebay
Link Removed
cheap as chips
take note if air freshener has been used, it might be to mask damp smell, smells like mushrooms or rotten potatoes.
ask when or if the exterior seals have ever been replaced and watch out for mastic around the trims indicating they have not been removed to reseal.
Check for soft spongy wood on walls and floor check inside all units any sign of new bits of wood on the floor or walls
Most vans of that age will have some discolouration around the bottom corner of windows due to condensation so be aware of that. check the fabrics for signs of mildew indicating a damp interior.underneath the cushions is the best place t look. There are some good vans out there of that age, mainly mercedes based and Hymers, Burstners etc. Good luck with your search. If your budget would stretch to £20K I do know of a fantastic buy before it goes on ebay.
43,331
49,467
first thing is buy a damp meter.
can be bought for less than a tenner.
then follow the instructions and check as many places as possible especially around ANY openings...windows, roof vents, floor to wall/roof to wall joints etc.
i beleive there is a small allowance for dampness but i cant remember what the percentage is...some one will know...but i think around 10%
have a good sniff around the cupboards...get your head in and snell, any mustiness could be wood rot.
check the floor for springiness as you walk.....this is delamination and can be very serious.
any damp then walk away.....it could cost thousands to correct.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
if it is real bad
If it is real bad your nose will tell you. But as Roger (Wildman said.. check the various areas.. common sense really).
We once vied an A class at a dealers that had been store for 4 months .. opened the door and boy you could smell the damp.
Bob
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Best way is to get it done profesionally, but you can do it yourself with the right type of meter. The problem is most of the cheap meters have two pins which you have to probe the surface with.
This type are pretty useless for a motorhome as the wallboard has a plasticised finish, so to get a readig you have to puncture the surface every few inches leaving holes.
You need a non invasive meter like the one below.
Link Removed
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Link Removed
That looks a clever piece of kit and what's £49 compared to the cost of rebuilding a MH.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
It is, I have both types of meter, the pinless one found damp in a van I was thinking of buying that the pins one didn't, then when I applied thumb pressure a hole appeared. Time for a Quick exit.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Non contact one good.
The pin type gives a high reading on my ceiling as the inner skin is aluminium, much the same as the plastic coating error but the other way round. This is because they don't actually measure moisture directly, but electrical conductivity.
darklord
1,241
1,230
essex
coachbuilt
three years
Dont get confused by damp meter readings. Use the meter on an obviously dry piece of wood inside the MH...inside of a wardrobe door or cabinet, note the reading, some meters will read in percentages, some bars, some just a band going up a scale,.....whatever yours was on the dry bit of wood, use as your benchmark.
Say it was 20, and most of the MH reads, 25, but some bits (around windows, in corners, floor near door etc) read 40-45...then you may have a problem.
Mine was done at Newark by a pro company, cost me £35...worth every penny as you get a report. Myself, I would use a tester, then if i fell in love with a van...get the pro's in, their report will either make you walk away, get the dealer to do repairs, or get a large discount::bigsmile: (if you are a gambler).
slobadoberbob
6,151
1,960
25 years & counting
is the van back this coming weekend?
Is the van back this coming weekend? I bet you will have that meter out.... hoping to see it at Peterborough.
Bob:thumb:
darklord
1,241
1,230
essex
coachbuilt
three years
Yup, this weekend, looking forward ti it. I will be taking readings and marking them on a "map" of the van like the pro did, then i'll have something to use in the future for reference.
Before this years lay up, about October, I,ll have all the seams resealed.
See you at P'bog.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I can't think of any technique that would measure dampness through a metal skin. Very unusual construction for inside.
