How often do you top up your batteries (3 Viewers)
CJB
140
60
Kent
1 year
Hi,
I have a couple of banner batteries in a bank, however they seem to need topping up quiet regularly although I never really discharge the batteries and I thought discharge cycles was the main reason water in the cells would go down.
Any idea how often they should need topping up?
Feb 9, 2008
8,953
18,710
Corby, Northants
Coach Built
I too have newish Banner batteries (about 1 year old now) and have asked the same question. I was advised to check them once a year and checked them after 6 months to find they did not need topping up at all. I will probably check again around Christmas time and top up if required.
Sounds to me your on top of it through.
GJH
29,450
38,827
None, now sold
2006 to 2022
Our battery is checked during the habitation service and I usually check it around about half way between services.
It's a Banner which was on the van when we bought it in February 2012 so I don't know how old it is. It is kept topped up by the solar panel.
I normally just have to put a dribble of water in each cell.
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
3 forktruck batteries on mine with a big Ctek keeping em in good condition. Check water at least three times a year and they usually take a drop but do get some serious abuse.;)
JockandRita
11,468
150,291
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
i check my trojans every three months and they do usually need a little bit
Similar routine here too with our Trojans (y)
Cheers,
Jock. :)
43,337
49,538
Cycling batteries shouldnt really have any bearing on electrolyte levels but overcharging at too high a voltage does.
14.4v is a safe bulk charge (bang volts in quickly) voltage, 13.6v safe absorption (final charge)voltage and 15v will start them gqssing and using electrolyte (overcharging)
If it regularly needs topping up, every month or so, either your batteries are faulty or your charger.
My last set gassed badly, took over 1ltr to top each one up (4 batteries) and an overnight charge.
Next day each showed 12.6v an hour after charger disconnected.
Two hours later, stood on the bench, each showed 7.5v
Nowt wrong with the charger but the batteries were totally knackered.
Feb 22, 2011
9,800
20,205
Newcastle under Lyme
Hymer B544 A Class
Since 2015
My batteries are under the seats and difficult to get at. What do they have, little screw plugs that undo ?
I`m not sure I`d be able to get in to visually check fluid level so what do others do ?
I believe the seats have to be removed to access batteries, they are ISRI ? seats
Aug 6, 2013
11,956
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Same here. ISRI seats weigh a tonne so I release the four screws then slide the seat forward until it topples onto the steering wheel. There's just enough room to remove the cell caps & if necessary top-up. Do disconnect the negative lead before topping up - there's not a lot of room to work.
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
GEL batteries, never checked them 10 years old now and still OK, but no point checking as you can't.
Martin
Oct 1, 2013
7,513
19,954
Lanzarote
Nil by mouth
Lots
I thought all batteries nowadays were sealed. Oops, never checked mine.
Lucas jobbies. Tap water ok?
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I wouldnT use tap water i Lanzarote in i would boil it first. Too many minerals in the water in the Canaries
Oct 1, 2013
7,513
19,954
Lanzarote
Nil by mouth
Lots
Surely boiling doesn't get rid of minerals?
Probably better to use bottled water ?
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Distilled water? Just defrost your freezer, break off a few bits of ice from the inside for pure H2O (be sure to remove any peas)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
They stick to the side of your kettle just like back home in hard water areas.
Here in Scotland we can use it straight from the tap as it is a soft water here.
(Learned on a training course for battery powered scissor lifts.)
Oct 1, 2013
7,513
19,954
Lanzarote
Nil by mouth
Lots
Did the same when in Bradford :)
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Same with mine, "Sealed for life". Just a little window which shows the level of charge by changing colour!.
Pete
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
since 2011
We have Sealed AGM Banner batteries don't need checking worked fine for last 15 months.(y)(y)(y)
May 6, 2010
547
638
Doncaster
April 2010
Bank of Trojans set to charge at the correct level, 14.8v
I check them every couple of months, I have the Trojan Hydrolink system installed, drop one end of the fill tube into distilled water ( which is cheap as chips, why risk contaminants getting into the batteries! ) connect the other end to the one way fill valve that feeds up to each battery, pump for a few seconds and each individual cell has a float cap that shuts of the fill of water when at the correct level. Sorted (y)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Same here in Mansfield Notts supper soft water a Huge Japanese textile company selected Mansfield for its new factory based on its soft water
BUT I own a Garage so have to buy the proper stuff,:Eeek: or be accused of bodging it:doh:
Oct 1, 2013
7,513
19,954
Lanzarote
Nil by mouth
Lots
When Bradford was one of the world's biggest wool cities, they built reservoirs up in Yorkshire Dales to get soft water for washing the wool.
Nov 18, 2011
11,862
43,055
Planet Earth
A van
Over 25 year's
always buy batteries with removable caps have your electrolyte checked regularly top up when necessary with distilled water
leave your lights on from time to time to discharge the battery charge with a good charger with a recondition recovery mode this will reduce the sulfate or eliminate it
this will help to clear the sulfate from the battery plates and put the sulfate back into solution turn it back into sulfuric acid
how do i know this just come off a one week flooded lead acid battery maintenance course covering soler forklifts and automotive
bill
Reactions: GJH
Ricardoe
131
64
West midlands
Hymer544
Just started
So..is it a good idea to flatten your battery now and again...every time I've had a really flat batt. its never recovered !
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Flat would be 12 or 12.2 volts, and less and you run the risk of damage.
Martin
