how long is a piece of string (1 Viewer)
pops
544
697
south glos
Pilote panel van
since1997
Ok story so far, We were 6 days into our 3+ month tour of Scotland when are Combi 4E packed in giving heat on the low setting. Gas is ok, but high setting we are only getting low heat. I suspect that a element has gone. We have a fan heater to help out in very cold weather and have bought another one as a backup. The van is just over three years old and I reckon that the heater has been on for roughly 3,000 hours in that time. So ladies and gents the question is do you think this is good or would you expect a longer life. Hence the title How long is a piece of string.
We are still on our travels and we are ready for anything the weather is going to throw at us.
2,360
10,257
Sorry.. I don't have a piece of string to measure.. .. our Truma boiler is gas only ..
I guess that makes mine 0.0 cm :D
43,351
49,588
The length of a piece of string is an equation with a variable answer.........your boiler is a piece of string.
Anything electrical or mechanical can fail at any time.....and without warning.
Gellyneck
9,249
18,346
More than toes wet now!
I could be wrong (probably!) but Truma may give a three warranty on the 4E and might give some "goodwill" if it's just over three years old? Might be worth a call to them?
53,511
150,381
At 3000 hours sounds like well past it's sell by date, I've seen reports on the web of the heating elements only lasting about 18 months of normal use. They work better on gas anyway and a lot cheaper to run.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Is the string lying down or standing up ?
It's not clear wheather you want the Length or the Height:D
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
The electric part is only 1800 watts if I am right and that will not give a lot of heat, start up on gas get the temperature up then keep it going on electric hook up. Was it any different before???? Cold weather show all the deficiencies in the vehicle insulation and it takes a load more heat to keep it warm more than the electric coil can give.
filopastry
1,016
1,738
london
littleun
newbie and learning every day
All string no matter what length is exactly twice half its length
Feb 16, 2013
19,747
52,090
uttoxeter
ambulance conversion
50 years
Another of those threads where someone asks for help and never returns:( this gets me far more uptight than any snipeing or abuse.
Alistair33
1,079
3,258
North Yorkshire
Hymer
It's a question of etiquette I'm always cautious of jumping back in to soon and not allowing enough time to get a good sample of responses before coming back, and I can see how it would be possible to forget to make a further comment!
Feb 16, 2013
19,747
52,090
uttoxeter
50 years
Yeah but this thread is a year old, surely he could have remembered by now:(
Cleve
789
2,333
France
Hymer 654
I don't know, I go to do/fetch/look on eBay and by the time I get to it (sometimes seconds later) I can't think what the hell I am there for. Retracing my steps does not always work. Thank goodness I am retired, I'll be able to push in at the post office soon, if I can remember why I went there!:imoutahere:
Stretto Boy
1,503
307,107
Leicestershire
Since 2011
String may be measured in several ways:
1. If it is extremely long (say several trillion kilometres) then take it to a large (clearly enormous) darkened room. Shine a torch from one end to the other, with the aid of an assistant who times how long it takes for the beam of light to reach the other end of the piece of string. Accurate measurements are essential, so an atomic clock is required. It is also important that the timekeeper has instantaneous reaction times in order to turn the clock on and off at precisely the right moment. When you know how long it has taken for the beam to traverse the string, you can calculate the length of it for we know that light travels at a constant speed of 1,079,252,848.8 kilometres per hour.
2. For much shorter pieces I recommend the use of a ruler, although method 1 can be used if extremely precise measurements are required.
3. The cheat's method is to read the measurements on the packet that the string came in.
Please note that none of the above is in any way related to what nuclear physicists term "String Theory".
I hope that this is of some assistance.
P.S. I have a Truma Combi 6E. Perhaps this is a later model than your 4 but mine works without any string being involved at all :)
Alistair33
1,079
3,258
North Yorkshire
Hymer
HHGTTG ?
pops
pops
544
697
south glos
Pilote panel van
since1997
@chaser, I am sorry I have not replied,but as we were on tour and it is nearly one year ago I suspect we could not get internet to reply at the time. We are on the same Scottish tour as I write and have been without lnternet for seven days. The answer to the question is Truma said that 3000hrs was a good life time for the elements.
The elements were both changed last October and all is working ok.
Weather in the highlands is cold and windy with sunshine now and then at the moment. Thanks to all who replied.
