How does this come apart? (1 Viewer)
163phil
283
273
Kenilworth
Coach built
Still only a year after many years camping
I've been fitting a reversing camera to our 2003 Autotrail Apache 600 today, and want to take power to the wireless camera from the rear corner, where there is access to 12V... if I can get in!!
Link Removed
The end panel is hinged on the top, (so must open!), and underneath there are two screws, which only seem to hold the vertical partitioning. Gently levering the front panel shows it to be well and truly held down, but I just can't work out where it's fixed!:Doh:
I don't want to force it, but can anyone tell me how to undo this accursed little panel?
Thanks in advance for any suggestions:thumb:
Minxy
32,656
66,564
E Yorks
Carthago Compactline
If it is anything like the ones we had in our Chausson Flash 04 - it too had hinges on the top section so in theory should have opened, however at the bottom of the front section there was a bracket which held it in place. If you can't get to this bracket you've had it! :shout:
Just a thought - how do you know there's 12v in there?
163phil
163phil
283
273
Kenilworth
Coach built
Thanks for that! - makes sense what you say. I know there's both 12V and 240V in there because[STRIKE] I have x-ray eyes[/STRIKE] there is a12V strip light over the sink and a 240V socket just under the end panel:Smile:
Looks like I might have to have the cupboard wall out to get at the bracket:thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
There are two screws holding a catch ( or something ) at the bottom, could they be doing a cunning double job.
Taking a MH to pieces is a great game. Worthy of Poirot.
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
If it's like my apache 700.. probably glued in place..
Just wait and eventually it will just drop off on its own. :ROFLMAO::ROFLMAO:
Sorry, could not resist...
Jul 28, 2010
1,710
617
The world
Small car
what a belter that was not laughed as much for oh a day
very good :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
43,331
49,465
taking out the screws wont release the cupboard upright panel either.
it will also be screwed from behind the ' hinged panel' into the stepped part of the shelf and maybe further up as well.
the cupboard will have been built on the bench and installed in the van as one piece.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I usually have no problem taking anything to bits :ROFLMAO:
Its the putting all the bits back I sometimes struggle:Doh:
163phil
163phil
283
273
Kenilworth
Coach built
Hmm, makes it a bit more tricky. So why the hinge, and are you telling me it's "sealed for life"?
I'll have another look tomorrow :thumb:
Minxy
32,656
66,564
E Yorks
Looking at the pictures I did actually think the bottom might be glued too. ::bigsmile:
Phil - Could you make an opening on the inside of the cupboard in the side panel shown in the photo and gain access that way? You could then use a cover over this once you've done what you want, such as a normal double gang socket blanking plate like in the below link using normal wood screws (the opening would need to be smaller than the plate obviously!) so that you could still get in to the wiring if needs be in the future.
http://www.wickes.co.uk/mk-double-blanking-plate/invt/195094/
Alternatively make your own cover.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Easy, 4lb lump hammer, will have it open in a trice. :winky:
Minxy
32,656
66,564
E Yorks
Yeah but trying to find a 'cover' that's lump hammer head smashed shaped could be fun!!!
Minxy
32,656
66,564
E Yorks
I would imagine you are going to have to take the entire cupboard of the wall
Nooooooo!!!!! It is highly unlikely that you'd be able to get it out in one piece and even more unlikely that it would go back as it should! :Eeek:
I'd make the internal access point in the cupboard as I've already suggested as at least it would be hidden from view normally and if you can get some matching wallboard you'd make it almost invisible once covered over. :thumb:
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
Why the hinge? Don't know for certain, but its likely it is the simplest and most cost effective way to keep the contour along the top of the doors.
Jun 17, 2012
2,933
9,931
North Essex
Autotrail Delaware
>12 but <13
Camera
This may sound silly but won't you be routing a cable for the video to the front of MH? If so, why not include the 12v feed which you can connect near the fuse box?
You're going to tell me it's bluetooth aren't you?
163phil
163phil
283
273
Kenilworth
Coach built
Yep:ROFLMAO:
Well, it's a new morning and it looks like I hadn't really thought it through. If I connect to the interior 12V I'll have to make sure the circuit is energised before towing, sooo...
I might as well put a gel cell in the cupboard, turn that on before towing and recharge as required. (An old glider battery (12V, 7aH) should do the trick as the current drain from the camera and 2.4gHz transmitter is minimal):thumb:
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Simples !!
Why not phone Autotrail ! I believe they have a help line !! Never used it myself though !
My Scout had it all fitted at the factory !....:thumb::thumb::thumb:
163phil
163phil
283
273
Kenilworth
Coach built
The simple solution
Keeping to the old adage KISS, and having an old motorcycle battery (10Ah) to hand...
Link Removed
Link Removed
Should do the trick:Smile:
Thank you everyone for your suggestions:thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
bluetooth is good, pick up all the baby alarms, video from passing cars etc, then eventually you chuck it away and buy a wired unit and run it all to the front of the van, hee hee.
163phil
163phil
283
273
Kenilworth
Coach built
Maybe Bluetooth does, but 2.4GHz doesn't - I won't go into the intricacies of how it works, but any modeller will tell you just how interference-free 2.4GHz is:moon:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Dave Newell is now kicking himself around his workshop thinking why did I not think of that:ROFLMAO::ROFLMAO::ROFLMAO:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Some disastrous crashes at model flying site near hear, 2.4G, they think it's some computer equipment at a nearby supermarket. Other places have had similar problems. Frequency hopping is good but not perfect.
Hate to correct Wildman but Bluetooth will not pick up passing anything. The software protocol has to pair both devices with a password before they will talk. I strong signal could jam bluetooth.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That's a fudge. You'll forget to turn it on, you'll forget to charge it. Then you'll remember "hilldweller said it was a fudge".
The best advice you've had is the cut an inspection panel in the side and see what you are up against. Even if screwed from behind, the lightweight ply is so weak you can easily pull the screws out and re-fix with clips or magnets. You are a bit stuffed it it's glued.
There's a lot of wasted space in there, let your mind run free and use it.
