Hot water
Discussion in 'The Beginner' started by RS SPIKE, Jul 24, 2015.
  1. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    Hi, I can't seem to get hot water when I'm NOT on electric hook up.
    What am I doing wrong ??
    Which settings do I need please ??
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,958
    12,241
    Plympton, Devon
    This might help,
  3. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    I,ve had ultrastore on and the temperature on 70 for two hours and the water is still cold !!!
    Think I may have a problem :(
  4. Boycie
    Boycie Funster
    Sep 25, 2012
    299
    547
    West Cornwall
    Is there a green light on your ultrastore showing that you have gas and it has ignited.
    Phil.
  5. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,424
    7,777
    God's county. North Yorkshire.
    On mine there is a micro switch in the window that has to be closed above the vent. Also is the vent cover removed?
  6. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    Yes green light is on, can't see a micro switch !!!
    It's fitted to a elddis sunstyle gt 140
    Cover is removed as we are using cooker with no problems
  7. Boycie
    Boycie Funster
    Sep 25, 2012
    299
    547
    West Cornwall
    Try altering the heat setting and listen to hear if the gas fires up. Also if your hot water tank is not full the thermal cutout would have kicked in may be auto resetting or may need manual reset.
    • Like it Like it x 1
  8. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
  9. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    Can't seem to hear the gas tripping in or out !!!
    How should I do a reset on it ??
    As my manuals are at home :(
  10. Boycie
    Boycie Funster
    Sep 25, 2012
    299
    547
    West Cornwall
    It should be an auto reset. Switch off the heater leave for a few minutes then switch back on. While switched off run the hot tap for a few seconds just to ensure flow into the heater.
    If your green light is on then that shows that the pilot light is on with gas flow.
  11. ambulancekidd
    ambulancekidd Funster
    Sep 23, 2014
    663
    1,563
    Ayrshire Scotland
    There will be a gas manifold somewhere in the van. Its ridiculously easy to turn the supply off without meaning to. That's where I would begin my checks.
    Good luck..Robert.
  12. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,222
    3,632
    walthamstow east london
  13. namwaldog
    namwaldog Funster
    Jan 2, 2015
    493
    811
    Cumbria
    We have an Ultrastore and had the same problem until we removed this cover from the outside of the MH..
  14. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    All sorted thanks for everybody's comments x
  15. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,110
    13,565
    under a wand'rin' star
    Oops :rolleyes:
  16. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,370
    1,441
    Lancaster
    Great to hear, what was it / how did you fix it? (Just in case anybody else has similar problems).
  17. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    As Boyce said above :)
    The system had drained down and cut the system out !!!
    Pulled water through turned the ultra store off then back on, heard the gas tripping in and out then left it for 30 mins then I had red hot water ;)
