Hot water- help please!!! (2 Viewers)
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Have just switched on my trauma water heater and have succesfully managed to get hot water at normal pressure in the kitchen sink.
However the hot water supply to the bathroom is barely a trickle and is not as hot as the water at the kitchen tap. Also there is no hot water from the shower tap although the pressure is high.
Can someone suggest where I might look to solve the problem.
Norman
MikeD
3,936
3,697
London
IH PVC
1st use since winter storage?
Norman
Is it the first time you have used it since the frosty weather?
Mike:thumb:
11,932
9,097
Got to be a blocked /kinked pipe
terry
Jul 28, 2010
1,710
617
The world
Small car
Norman
you may have an air lock
run the tap to purge the system
the water from the heater is pumped through pipes to taps by putting cold water in to the boiler pushing the heated water to the taps
any heat loss should only be short time as the colder water in the pipe pushes through the heat should be the same in all taps/shower once its run long enough to purge the pipes of this cooler water
normanandsue
normanandsue
1,871
21,571
van conversion
Would 5 minutes be lon enough to purge the system?
If so have done this and no change.
Thanks Norman
MikeD
3,936
3,697
London
IH PVC
Frozen during the winter
Yes Mike it is
I wondered whether they got frozen up during the winter and the internal of the tap got damaged some how?
There is a plastic cartridge in the tap and may have been affected. They are not usually expensive - around £10
I hope this helps
Mike:thumb::thumb:
normanandsue
normanandsue
1,871
21,571
van conversion
I hope this helps
Mike:thumb::thumb:
Can't quite understand this Mike as the taps work fine with cold water and in the off position.
MikeD
3,936
3,697
London
IH PVC
Norman
Brian has a point. There are two feeds to the tap the hot one may be damaged or maybe cold is feeding across to the hot and either slowing or stopping the flow.
I am no expert but I can't think of another reason why something that worked ok last year, now does not.
Hope this all helps and not confuses
MikeD:thumb::thumb:
smiffy502000
249
124
sutton coldfield
coach built.
hi,if you still have no joy,try giving dave newell a call,he is the fountain of all knowledge and may well have the answer. his number you will find at the top of the page. good luck:Smile:
ukbill
5,501
5,274
Pinoso
4 berth low profile
sounds like a air block but the cartridge for hot and cold and different just cause the cold works dont mean the hot will the hot cartridge could be jammed in the closed position turn on your hot tap unscrew the head of your shower so you just have the hose try to block the hose then turn the cold fully on see if this clears the blockage try 1st with the tap open then closed
Scout
3,959
121,409
South Yorkshire
chic c line
could be a non return valve stuck closed,
a couple of years back my shower would not work,
it would work "on hot water position open only " if the water heater was not on IE the hot water was cold,
it turned out it was the cold feed non return valve stuck, not letting cold water mix in with the hot, because it was a thermostatic valve the the hot water was too hot (when it was hot not cold) so therefor shut down the valve.
I hope Ive explained this correctly.
jennyp19
75
33
Sunny Scunny
about 10 yrs
Probably not the same, but we had same problem a couple of months ago, didn't realise that there was a switch in the garage that had turned pump? off (we were still getting cold water but at a slower rate). OH must have knocked it when he was putting stuff in.
