Honda Genny Warning.... (2 Viewers)
Feb 22, 2008
12,266
45,055
Nearly Tugging
I bought a new Honda Eu10i genny two years ago and other than an occasional start up its been in my garage and never used in anger.
I tried it recently , filled with fresh petrol and under load it wouldnt run properly.
I took it into local agents thinking that under 5 year warranty it would be sorted.
Not so, because I had not had it serviced, even though it had not been used , I had to pay £59.40 for it to be corrected, apparently blocked jet in carb.
I paid a premium price for a so called premium product, but now wish I had bought a KIPPOR :eek:
The moral , even if you dont use it pay an agent to service it anyway :groan:
Jan 22, 2013
1,254
60,457
London SE
A class Adria vision I707
since 1971
It's a common problem unfortunately, as fuel has a 10% ethanol content the lack of use causes the fuel to evaporate leaving behind a varnish like substance from the ethanol, this will promptly block the main jet in the carb,
But it's a simple job to clean out the bowl and jet or if you cannot be bothered then you need to run the engine until it runs out of fuel,
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
Unfortunately there is no separate petrol tap so the only way is to tip the thing upside down to drain the tank , then run it dry .
I have a couple of B&S powered gennies which I use for non motorhome purposes and even with old petrol they always start first pull and dont miss a beat.
musson
487
165
grantham
low profile
since Jan 2014
Always pays to start it once a month should stop your problem.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Ah, but how much to service it for 5 yrs?
Cheers, Dave(y)
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
Mine still takes a few pulls and yet my B&S start first pull, i think Honda overrated .:rolleyes:
Abacist
3,752
10,828
Devon
N & B Arto 88F Tag
since 2013
Most warranties are invalidated by a lack of servicing!
Simon
287
426
Ramsgate, Kent
Swift Kontiki 600
First year under our belt!
Isn't that £59.40 cheaper than 5 years of servicing?
Edit: 2 years. Even so, still may be cheaper.
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
No. Can't rembeber the name, but the one Machine Mart sell.
Its difficult to know how long to leave petrol in for, will probably tip it out and run it dry after every use, unless I can find the feed and fit a tap.
Simon
287
426
Ramsgate, Kent
Swift Kontiki 600
Or just run it until it's all gone. Give it a work out, kindathing.
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
Just been and done that, tipped all from tank and then ran it to a standstill , might well consider additive to avoid emptying every time (y)
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
OK, perhaps I should have done this first.
READ MANUAL !!
For transporting and storage
Empty petrol from tank
Remove side access cover
Place end of two drain tubes over small container.
Slacken drain screw in bottom of carburettor
Remove spark plug lead
Turn engine switch on
Pull start cord to empty pump
Turn engine switch off
Tighten carburettor drain screw
Replace drain tubes
Replace spark plug lead.
Sorted (y)
Bit of a pain after every use though :rolleyes:
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Just annoying that a warranty is not worth the paper .........
I may be an old cynic but..............forget to register your purchase or do not 'service' (with proof) every year and there is no 'extended warranty' on a lot of items....... reasonable conditions? .........or just a 'get out'?
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
I also am a cynic, its a sales pitch with a cop out. Not many will pay £50 ish for an annual service on a very lightly used unit.
Oil change , clean filter, check plug , DIY much cheaper.
32,667
66,625
At the end of the day it is an engine ... all engines need to be serviced, some annually, some bi-annually, even diesel heaters (Webasto/Eberspacher) in MHs need servicing and regular use to avoid problems. One reason why we were happy NOT to have a diesel heater in our last 2 campers, one less thing to have to worry about and spend on.
Larrynwin
Feb 22, 2008
12,266
45,055
Nearly Tugging
Yes I agree on the servicing but this unit was basically unused from new and lack of servicing wasnt the cause of the problem, it was a gummed up carb jet.
Will have to drain down after every use to avoid a recurrence.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
That is not a Honda or a Honda Warranty complaint, that is a dealer taking the piss.
Any engine technician would have known that the problem would not have been solved by servicing once a year. Hence they just wanted their mitts on some easy money without the hassle and paper work associated with sorting out a warranty claim.
Suggest you email Honda UK highlighting this and see if they respond, before condemning Honda. They are the undisputed best !
9,551
32,140
sleights
c class
We leave the petrol in our lawnmower and never have it serviced ( a concious decision it did not seem worth paying for a service on a £100 mower) the last one lasted for 15 years!!!. Sounds like the Honda isn't as reliable as made out or optimised for fuel used in non UK markets
