hob pressure down (2 Viewers)
g4jnw
36
10
Anthorn, Wigton, Cumbria
Conversion
newbie
just got a campervan and the hob burners were full of crud, pipes now reasonably clear although 1 burner is still burning a bit yellow, its an old top so think i may have to replace it, firstly can anyone recognise the make and model from the picture, its a strange size 470mm X 381mm the van is 1995, cant find any markings on the hob at all to say what it is.
The other thing is the pressure is way down, all other gas appliances work as normal.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Low gas pressure may well be caused by a gunged up regulator ..... this is a well documented problem particularly with Trauma regs.
Pesonally, I would have the system checked and serviced by a qualified gas engineer as you say the hob is burning badly which will probably be producing CO (carbon monoxide) which is deadly poison.
I would also fit a CO detector in case of any later problems.
Cheers, Brian
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Good advice from Brian. A Gas engineer will give it a service, clean the jets and check the gas pressure with a water gauge. The yellow flame defiantly indicates that the air gas mixture is wrong and the gas is not being burnt completely. As said this is very dangerous and neat Carbon Monoxide, which is the product of incomplete burning, is oudourless, colourless and quite invisible. you only need a minute part of a lungfull to kill you, so get it serviced. It will be a well made product and perform well when properly adjusted.
G
g4jnw
36
10
Conversion
newbie
Cheers, Brian
Thanks Brian, yes i have a CO2 detector fitted, have only just got the van and am contacting a local caravan place to see if they do that sort of work, Im trying to figure out the make and model incase of replacement without having to alter the worktop.
Just a thought, if the regulator was bunged up would it still work the heating as normal because thats working as normal.
I am first going to try and get someone thats qualified to check out the hob to see if it can be serviced but am starting to think this may cost more than a replacement but not sure yet.
lunarman
2,156
2,451
South Glos
since 1994
I can remember when we dealt in 'real' money and measurements. The size you quote equates to 18.5 inches x 15 inches. Not so strange really. :RollEyes:
icantremember
8,333
17,545
Hymer T-SL668
since 2005
Thanks Brian, yes i have a [HI]CO2 detector [/HI]fitted, have only just got the van and am contacting a local caravan place to see if they do that sort of work, Im trying to figure out the make and model incase of replacement without having to alter the worktop.
I'm not being picky but I assume you mean a Carbon Monoxide (CO) detector as there is a big difference between CO and CO2 which is Carbon Dioxide.
Your heating may well still operate with a partly blocked regulator but probably not to full efficiency.
A qualified LPG gas engineer will be able to test the regulator and service the rest of your system hopefully without the need for a new cooker.
Brian
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Same for me, i get a youngster at work some times, i say "that looks about a inch and a half to me"
"what does that mean" ,he asks --so i have to get the measure out and explain, then realize it`s no good me teaching him, i got to go with this new fangled metric idea :ROFLMAO:
G
g4jnw
36
10
Conversion
newbie
Iam an old giit too lol - so better with feet and inches but all new hobs seem to be quoted in metric - anyone know a replacement of the above size, either metric or imprerial?
Made a boob on the last thread too, mean't CO (carbon monoxide) rather than CO2 - its an age thing!!!
