- Jun 29, 2015
- 3,482
- 57,485
- caravan (for now)
- on and off since 1984
Tried to change the heating settings but the app has gone down, hopefully back up soon. Hive will work without the app but it has to be adjusted manually
I'll try it, I started to get cold because even though my rads were on the heat on demand function needs the app to workJust tried app - it was very slow to load but seemed to get there eventually, so hopefully back up now.
Sorry, I mislead you - the app eventually loaded but it’s not working properly (as my wife has pointed out to me!)I'll try it, I started to get cold because even though my rads were on the heat on demand function needs the app to work
Should be ok. The thermostat communicates directly with the boiler so the engineer ought to be able to get your new boiler launched even if the app is playing up. My apps have been behaving ok for the last few minutes.I hope it’s back up tomorrow - I am getting my new combi boiler fitted
They've said not on a tweet to someone else...Could it be part of this?
Microsoft says services have recovered after widespread outage
Tens of thousands of users of Outlook and Teams were affected earlier on Wednesday.www.bbc.co.uk
I've just got access via website.The info on the hive site says voice control should still work but when I tried it Alexa told me it was set bit the temperature setting didn't change on the rad
I can login at the website but it only gives access to the main thermostat, the rads are shown but not working. Lucky with the hive system it will work by adjusting the valve manually, so we are not without heat.I've just got access via website.
App still not loading
my.hivehome.com
If the app goes down the system will work as a standard heating control without it, unless like me you have the smart radiator valves as wellI’m close to getting one of these before we go away to Spain. Now I’m nervous. Technology, sometimes wander if I just leave it set to come on everyday for a bit less time and set to say 15c!
no it's best to put the hot water on for half an hour at midnight, or you can monitor the temperature and switch it on boost from where you are as long as you have the internetGot ours fitted yesterday. But our hot water tank is in the loft and we will be away over February so want to be sure it’s frost protected. If we use holiday mode will the hot water tank get heated if the temperature drops below the target temperature?
