Hi people/hymer 544 help (1 Viewer)
Frenchsunlover
Hymer BC 544
Hi,
I'm Andrew, my wife Lisa and I love our Hymer and especially French summer sun!
We have a Bc544 and are currently sunning ourselves near Narbonne.
Our water pump has stopped working, fuse good, tested all tap micro switches, put 12v across the pump which works. No power across fuse connections on Elektroblock, I am assuming there is a relay
Somewhere in our l/h drive van.
Anyone out there know where the relay is before I get too smelly? Lol
Andrew
Momo
2,499
3,041
Valencia City, Spain
just looking
I'm a newbie.
Hi Andrew & Lisa and welcome to the Fun!:welc::party:
Can't help with your query but someone who can will be along very soon!(y)
Feb 22, 2008
12,266
45,062
Nearly Tugging
Hi Andrew
We have just obtained our B544 , 2003 vintage, after nosing around can only find the 5amp fuse in the main fuse board(Elektroblock)
in rh side of cabin.
Sorry cant help more. Good luck in your search and please post answer when you find it.
JackieP
666
1,400
Isle of Man
If you need help the guys at Narbonne accessories are very helpful, and if it's your pump that's failed then they sell them too.
jollyrodger
6,282
26,425
Devon/Cornwall
'Obby
Since 1968'ish
Hi from overcast Devon
temp wire bi-pass from anothe fuse ?
Feb 22, 2008
12,266
45,062
Nearly Tugging
PS
My handbook says 12v supply must be switched on for pump to work, mine also works with supply switched off , odd :Eeek:
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
Our Hymer 700 also blew its pump fuse, from memory it was a 5 amp, replaced it with a 10 amp fuse, no more problems. I recall the 5 amp is brown, and at the far end of the elektroblock, not easy to extract or replace. Good luck.
If you still have a problem, does the pump sound as if its under strain, if so, could be it needs cleaning out, may have collected some minute sand which is blocking the non return valve. If so, and the tank is inboard under the table, its not to difficult to extract and clean. If you intend spending time in sandy areas, a spare pump is a very good investment.
