Hi people/hymer 544 help
Discussion in 'Introduce Yourself' started by Frenchsunlover, Aug 1, 2015.
  1. Frenchsunlover
    Frenchsunlover Read Only Funster
    Aug 1, 2015
    3
    Lincolnshire
    Hi,
    I'm Andrew, my wife Lisa and I love our Hymer and especially French summer sun!
    We have a Bc544 and are currently sunning ourselves near Narbonne.
    Our water pump has stopped working, fuse good, tested all tap micro switches, put 12v across the pump which works. No power across fuse connections on Elektroblock, I am assuming there is a relay
    Somewhere in our l/h drive van.
    Anyone out there know where the relay is before I get too smelly? Lol
    Andrew
  2. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Valencia City, Spain
    Hi Andrew & Lisa and welcome to the Fun!:welc::party:
    Can't help with your query but someone who can will be along very soon!(y)
  3. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,808
    13,724
    Norfolk
    Hi Andrew
    We have just obtained our B544 , 2003 vintage, after nosing around can only find the 5amp fuse in the main fuse board(Elektroblock)
    in rh side of cabin.
    Sorry cant help more. Good luck in your search and please post answer when you find it.
  4. JackieP
    JackieP Funster
    Mar 10, 2010
    274
    658
    Isle of Man
    If you need help the guys at Narbonne accessories are very helpful, and if it's your pump that's failed then they sell them too.
  5. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,581
    7,196
    Plymouth
    giphy.gif Hi from overcast Devon
    temp wire bi-pass from anothe fuse ?
  6. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,808
    13,724
    Norfolk
    PS
    My handbook says 12v supply must be switched on for pump to work, mine also works with supply switched off , odd :Eeek:
  7. nomadic
    nomadic Funster
    Sep 27, 2007
    682
    182
    Shropshire based
    Our Hymer 700 also blew its pump fuse, from memory it was a 5 amp, replaced it with a 10 amp fuse, no more problems. I recall the 5 amp is brown, and at the far end of the elektroblock, not easy to extract or replace. Good luck.
    If you still have a problem, does the pump sound as if its under strain, if so, could be it needs cleaning out, may have collected some minute sand which is blocking the non return valve. If so, and the tank is inboard under the table, its not to difficult to extract and clean. If you intend spending time in sandy areas, a spare pump is a very good investment.
