Same here I bought the blue one instead of the white one It works perfectly well though and I agree it is one of the better gadgetsI think that the advice is that if you are not sure you should buy one that works without an overflow (I think this is what I ended up with and later discovered I do have an overflow).
I have to rate it as one of the better 'gadgets' I have bought for the van.
When you filled it up before did it come back out of the filler neck? if it did you don't have an overflow
Can anyone tell me which water tank is on a 2014 Autotrail, is it with or without overflow. I have just bought a Heoswater universal connecter so suits both systems.
I have an overflow, but if I am are filling from a high pressure supply, and if not watching.. it comes out the filler and also floods underneath the van
so for that reason if I were buying, I'd buy the one for NO Overflow.
No it will overflow at the fillerI have been thinking someone must make a proper filler cap for this tank......... I wish I had known. The universal now covers both a vented and un-vented tank, do I assume that if you set it up as an un-vented that once the tank fills it in effect stops the water with some built in valve?
The vented tank filler simply has a seal and the non vented has the seal removed so it will leak out of the attachment point
