Heoswater Connector (1 Viewer)
May 23, 2012
373
342
Anglesey
Rapido 666f
Can anyone tell me which water tank is on a 2014 Autotrail, is it with or without overflow. I have just bought a Heoswater universal connecter so suits both systems.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
When you filled it up before did it come back out of the filler neck? if it did you don't have an overflow
Mar 11, 2014
934
1,330
Lincs
PVC
Since 2010
I think that the advice is that if you are not sure you should buy one that works without an overflow (I think this is what I ended up with and later discovered I do have an overflow).
I have to rate it as one of the better 'gadgets' I have bought for the van.
GJH
29,450
38,827
None, now sold
2006 to 2022
Same here :) I bought the blue one instead of the white one :) It works perfectly well though and I agree it is one of the better gadgets :)
scotjimland
2,303
9,970
A Woosh bang
I have an overflow, but if I am are filling from a high pressure supply, and if not watching.. it comes out the filler and also floods underneath the van o_O
so for that reason if I were buying, I'd buy the one for NO Overflow.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Broken Link Removed
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have been thinking someone must make a proper filler cap for this tank......... I wish I had known. The universal now covers both a vented and un-vented tank, do I assume that if you set it up as an un-vented that once the tank fills it in effect stops the water with some built in valve?
Techno
Jul 28, 2010
15,475
20,756
May 2010
No it will overflow at the filler
Feb 24, 2013
13,075
101,438
Bolsover, Derbyshire
Hymer S800
not long enough
Please don't all laugh out loud at me, but where does it overflow from? :) My tank has no over flow, I cant see an outlet in this cap
My inlet pipe often airlocks and therefore blows water back out, would this still blow back out of the 'secret' overflow? o_O
Techno
Jul 28, 2010
15,475
20,756
May 2010
The vented tank filler simply has a seal and the non vented has the seal removed so it will leak out of the attachment point
Techno
Jul 28, 2010
15,475
20,756
May 2010
Ebay seller picture is non too clear but basically you remove the seal for a non vented tank
Feb 24, 2013
13,075
101,438
Hymer S800
not long enough
Thanks Andy, lets hope it cam leak out as quickly as it comes out of the hose, I am really bad at turning hose on and walking away :)
