Helppppppp Papajohn or anyone please (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Ok not major problem but......
My batteries charge on solar or hook up to 14.3 amp.
When off hook up they slowly run down at what i would think at a normal rate.
Till they get to 12.8 then they suddenly crash to 11.1!!!!
I presume i need new batteries?
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
yep
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
sounds like you have more than one battery, my bet is one has failed, you probably only need to identify and replace that one (y)
I know this because I bought 2 for mine, then found I only needed one :doh:
I was amazed that one failed battery can so badly affect the total voltage
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
How do you find out if it's just one that's failing and which one?
turn off the charger, disconnect batteries from each other then check the voltage with a meter
or you could use your controller for an indication of voltage if you don't have a meter, just connect one at a time
(y)
Munchie
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
As they are both the same age I will replace them both so as not to end up in the same situation further down the road.
But thank you!
scotjimland
2,324
10,061
A Woosh bang
But thank you!
That is the best plan..
ideally, batteries or cells in banks should be
* same make
* same capacity
* same age
The pedantic will even try to buy with consecutive serial numbers so they are as near identical as possible..
