Help with control panel light on please (2 Viewers)
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Newbie from Oct 2011
Hi all,
In our new van we have an analogue control panel and all has been fine but on coming home yesterday we had an intermittent beep and the green mains light (bottom right) is on and top left where it says B1 S1 the bottom R red light is on. We have checked water and all is empty, valves closed etc so really not sure now what this means, we are home, parked up and the lights are still on this morning. Any ideas gratefully received, also will this drain the 12v battery. Electrics are so confusing, ask me a knitting question instead LOL. :Smile:
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Oh dear, your're all quiet. May have to try phoning dealer we bought it from see if they know. Thanks anyhow
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Update: Filled it with more water and lights all went out which is fine but I dont really want water in the tank continually as it will go stale. Will empty out tomorrow and see if lights stay off. :Smile:
aba
2,775
1,112
yorkshire
dec 2009
you will probably find its the fresh tank warning light to tell you its empty.
if you are not using the van switch off the main 12 volt power switch which should turn all the lights out.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Knock the switch off for the electrics, as already said. There should not be anything on!
Usually a switch the says engine/leisure or similar can be left on it's middle position to isolate the lot.
If you head down cornwall on your travels, give me a call and I will be happy to talk you through your controls if you are unsure!
