Help with control panel light on please
Discussion in 'The Beginner' started by Lindylooj, Jun 21, 2012.
  1. Lindylooj
    Lindylooj Read Only Funster
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Hi all,
    In our new van we have an analogue control panel and all has been fine but on coming home yesterday we had an intermittent beep and the green mains light (bottom right) is on and top left where it says B1 S1 the bottom R red light is on. We have checked water and all is empty, valves closed etc so really not sure now what this means, we are home, parked up and the lights are still on this morning. Any ideas gratefully received, also will this drain the 12v battery. Electrics are so confusing, ask me a knitting question instead LOL. :Smile:
  2. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Oh dear, your're all quiet. May have to try phoning dealer we bought it from see if they know. Thanks anyhow
  3. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Update: Filled it with more water and lights all went out which is fine but I dont really want water in the tank continually as it will go stale. Will empty out tomorrow and see if lights stay off. :Smile:
  4. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    you will probably find its the fresh tank warning light to tell you its empty.
    if you are not using the van switch off the main 12 volt power switch which should turn all the lights out.
  5. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
  6. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Knock the switch off for the electrics, as already said. There should not be anything on!
    Usually a switch the says engine/leisure or similar can be left on it's middle position to isolate the lot.
    If you head down cornwall on your travels, give me a call and I will be happy to talk you through your controls if you are unsure!
  7. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    What does this mean? read the manual? If so I did and it actually doesnt say what all the lights mean. :Smile:
