help with CD camcorder (1 Viewer)
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I have been using my camcorder and the battery was low, so I switched it off and removed the battery to fit a charged one.
When I switched it back on ---------it cam up with a message ---format or lose all data. what am I supposed to do ?? I would rather not lose all that is on the disc.
Help !!!!!!!
Nigel
43,329
49,446
Help !!!!!!!
Nigel
format possibly means to finalise the disc to view on any machine.
just a thought.
Benni-Boy
47
Halifax
30 years
Format means wipe everything. Finalize allows the disc to be played on any machine. Is there a button to press that says finalize? If so press that rather than wipe everything. Good luck:thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I would remove the disk then put a new one in and see what happens, maybe make a copy on the computer as well
S
sinbad1
I agree with wildman do not select format, remove the disc and make a copy try your copy look for the option to finalise, if this is not possible could be the disk data may be corrupt.in which case you will need a program to repair/finalise.
Could be that removing and recharging the battery without finaliseing the disc, and then could be your camera is seeing the disk as a blank and therefore wanting to format (whenever i put a new disk in the cam formated it to a chioce of two types can't remamber what they were)
I had a sony dvd recorder (in fact its in the cupboard somewhere) had lots of problems with it one of my worst buy's
Regards
S
sinbad1
just seems strange it should say...... format or lose all data.
I don't understand that John ;but format is format and thats erases all data could be a foreign jobby with mixed up translation.
anyhow if he copies the disk there is a chance of recovery and could risk the format option? have to wait for his feedback
if we knew the format of the images on the disk we could perhaps find a program to finalise then burn to disk?
Sherpa
26
Wiltshire
Van Conversion
25yrs with breaks
Have you recorded anything on this disc before, if you have then I'm stumpted, but if this is the first time, then like Sinbad said, could be your camera is seeing the disk as a blank and therefore wanting to format , which actualy means there is no footage on the disc or sd-card, you normaly have to format the disc before recording.
I don't know what type of camcorder you have, but as far as I know there is no way or reason to finalise a camcorder disc, if this was at all possible you would then not be able to record any more footage on that particular disc or card.
I can think of no other reason for your error message, and if I'm correct then sadly you have been filming absolutely nothing.
Hope this helps
S
sinbad1
I don't know what type of camcorder you have, but as far as I know there is no way or reason to finalize a camcorder disc, if this was at all possible you would then not be able to record any more footage on that particular disc or card.
Hope this helps
You may be right all may be lost ,failed finalizing is a common fault with camcorders but if the data is there then could be a chance of recovery.
Finalizing or closing of a DVD is to prevent additional data being added to the disk and make it usable on PC's and DVD players.
The problem is if it isn't finalized then the PC or DVD player will not be able to read it or play.
This all depends on the value you put on the footage of the disk, there are several companies that will do this for you (at a price) you can find these by goggling.
However, it is possible to do this yourself if you have the right software Nero9
there is a trial version Link Removed
More info and how to recover unformalized disks using Nero Link Removed
Regards
Sherpa
26
Wiltshire
Van Conversion
25yrs with breaks
Problem is,, We don't know what type of camcorder this problem relates to, is the data recorded on a cd, an sd-card or an hd drive or what, if its recorded on a cd then it would need to be finalised in order to play back on a PC or TV, which means a new disc would have to be inserted for each session.
Seems like this data has been recorded on a cd or mini dvd, and when the camcorder battery lost its power the machine assumed the session was over, therefor there would be a choice of either reformatting and losing all data, or finalising and saving existing data.
Sinbad, you suggest making a copy of the disc, but how can a copy be made if the data is not readable ?
Sundowners
Sundowners
3,289
3,571
37 years
:thumb:Thanks for all your advise guys:thumb:
My laptop went flat and I was having too much fun to bother re-charging it (I still have to run genny to charge it)
I found someone who knew what to do !!!! I think she just finalized it? Then we put in a new disc and formatted that, we saved all the film on the first disc and on Sunday I neally filled the second ---------entirely of the MUD RUN !!!!!!!!!!!!!!!:ROFLMAO:
Nigel
American Dream
156
Lincoln
Nigel
Glad you got it sorted Guys.:thumb:
