Help Required - Ford Transit (2 Viewers)
Mar 21, 2010
2,486
2,993
Hi can some one out there offer any advise on the on going problem I have with Hobby based Ford Transit.
June 2014 traveling up a very small hill, start to lose power and computer states "engine malfunction". Called out "Ford Assist" (AA) who thought it was a problem (via their computer) with the EGR valve!
July 2015 as above
September 2014. EGR valve cleaned
End of September same trouble again!
October 2014. New EGR valve fitted
December 2014 3000 miles later same problem. "Ford Assist" once again say EGR (via their computer)
January 2015. On the way to ET from Devon, once again same trouble this time we call in to the local Ford Garage at Redhill . On their diagnostic checks could not find any faults!! They then fitted a new Fuel Filter.
Jan/Feb/March 2015 4ooo mile around France and Spain no trouble
May 2015. Trip to Newbury Show, once again lost power on very small hill. switch off engine and restart everything OK. this happened about three times on the way home to Devon. Engine computer shows "engine malfunction
PLEASE has anybody got any suggestions as this is starting to cost a fortune every time I visit a garage and I love this van and don't want to sell it!!
colyboy
karl c
231
247
since 2010
Transit EGR pain in ass, there is a spray you can buy to just spray into the in take.
get a OBD reader off ebay and reset it your self.
you may not be driving it hard so the EGR clogs up, just spray in as it say on the can.
Microchip
138
126
Hampshire
Low Profile
Had the same problem but on a Fiat 2.8 jtd.
Any small incline and engine management light comes on, then the fault would disappear for a while.
In the end I took it to a small local Fiat garage and they found the turbo waste gate valve was tight and was sticking intermittently.
Hope the may help.
Keith.
karl c
231
247
since 2010
this fault in transit all the time from new they change them only if the engine light come on, if it sticks open you lose power. This is the same on most with an EGR.
colyboy
Mar 21, 2010
2,486
2,993
KARL
What spray do I need and where can I get it?
colyboy
karl c
231
247
since 2010
EGR Valve cleaner about £12 for any car shop or Halfords, just follow that on the can .
I did our car twice then with the OBD reader cleared the code. just keep them both in the van and do again if needed.
Dec 10, 2013
3,423
12,248
South Staffs
Pilote P740GJ
Have you tried driving it as though you have just stolen it.
Joking aside every time I come down a motorway slip road I give it a good thrashing in the low gears.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
That is what mechanic told me to do. Once warmed up as you leave a roundabout just thrash it hard through the gears. He said delivery vans never have this trouble, haha
Dec 10, 2013
3,423
12,248
South Staffs
Pilote P740GJ
Just another thought, have you Googled some of the Tranny websites. You can pick up some good tips off them.
karl c
231
247
since 2010
we have an old P reg transit and I have to get the wife to take it for the mot, as when I take it fails . then she takes it back and passes . she has a lead foot.. (y)
andy63
4,672
15,018
south shields
since 1990
Hi @colyboy as has been mentioned the Ford transit forum is an excellent forum with a lot of very knowledgeable lads... They could point you in the right direction..
If your problem is egr valve related and it persists there is a lad Martin on there who can do you a map for ecu that deletes the egr function... I've been running it for a month or so now and all is good... you will need to clean the intake side from turbo to inlet ports before you get that done... I have posted a few pictures of what's entailed on techno 100 thread on egr valves...A quick search in tech and mechanical section should find it.
There is a manifold pressure and temp sensor in the air intake pipe to the inlet manifold which also gets fouled.
On mine it's by the egr valve inlet to the manifold... easily removed and cleaned with carb cleaner....that can help.
The sprays mentioned above may be ok but I reckon a short term solution if it is the valve sticking....
Could be turbo related but you don't mention any codes relating to that...
Anyway hope this helps...If you want any details on above points just get in touch...
Ta andy
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I blanked off the bloody thing simple jobe took ten minutes, bought the plate from ebay and it is the same for Jaguar cars with the same engine. Otherwise give it a damn good thrashing like John Cleese did. Honestly give it a bit of stick sometimes, but the plate is the permanent fix. You will find the whole lot a sticky black oily carbony mess, the idea is the the Nox is reduced, It may be but the gunge must really foul the inlet manifold and that is why you get loss of power. The particulate filter also needs a bit of welly to clear it.
As the man said Parcel delivery vans do not suffer, I get passed by them doing 90 in morning off to do their rounds.
andy63
4,672
15,018
south shields
since 1990
hi, its not that simple on the later engine vans like the mk7 transit....the egr is electronically operated and has a feed back to the ecu...simply blanking them will most probably throw a fault code and possible limp mode... unlike a purley mechanically operated valve.
the only way I know of is to delete the egr function from the ecu....see my above post...
ive also been told about giving the engine a good drive but not sure about that one now, as the egr valve is designed to work during steady efficient driving conditions and not during say tick over and hard acceleration...
I really don't know why some engines suffer so badly and others seem to be ok.....as I indicated above I cleansd my inlet system before deleting the function from the ecu, but really it wasn't as bad as I had expected..
ta andy
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I think they make a blank with a smaller hole that allows some flow and will not trip the electronics.
andy63
4,672
15,018
south shields
since 1990
yes ive heard of them. but my thinking is if the egr valve is faulty and sticks open you still have the problem of the gas entering the manifold when you don't want it to, causing the same fault , ie eratic idle loss of power etc...
it may be the more expensive option but imho, getting it written out of the map is the best option on the electronically controlled valves..
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
It would still go in there without the blanking plate BUT it is far less liable to get gunged up with the plate there. It also is more efficient when no breathing in it's own exhaust.
