Help - New Tap Needed (2 Viewers)
Oct 20, 2013
5,299
13,199
South Norfolk
Yes
Does anyone know what make of tap this is?
It's a shower tap fitted in a 2002 Autotrail Scout. I've contacted AT and they've said they can't help as it's not the original, that evidently was gold coloured, (don't know who found it necessary to change all 3 taps in the mh at once.) I think they're lying to me, but what can I do.
May 29, 2013
2,603
19,279
Tyneside
Chausson best of Flash 10
Several years now
Ebay has loads of bathroom type places advertising, get a few phone numbers / email addresses and talk to them.
Mar 23, 2015
93
122
North Nottinghamshire
Autosleeper Kemerton
Since 1989
Hi is it leaking? or what is the reason for the question? After our moho adventures (there for all to see) I consider myself a bit of a tapologist? the repair to ours cost me 20p? New tap £90.00!!
Jun 30, 2010
7,925
27,236
1992 VW Auto sleeper Mono
Since 2005 this time
Try Alastair Murray (parts manager)
01332781562
or
alastair@geoffcox.co.uk
You might need your vin# to give to him, he's sourced a few things for me in the past, excellent service!
Dawn B
Oct 20, 2013
5,299
13,199
South Norfolk
Yes
It's leaking, but only after it's been used
Dec 12, 2010
5,415
21,601
Cumbria
Looks a bit like a Reich tap to me, you can get a new cartridge insert for them for about a tenner off eBay (y)
lesr48
98
85
Ilkeston, Derbyshire
Rimor Katamarano
Since 2014
I did the Autotrail factory tour last week ( very interesting too.. ) and the guide told us that all of their taps were currently available to buy in B & Q
Jul 5, 2013
11,731
13,711
Dawn. Didn't know you showered.
Seriously, exactly where is it leaking from. Is it from the bottom of the flexible tube on the left in the photo? In that case all you probably need is a rubber washer.
11,932
9,097
Hi Dawn if you go for normal house hold taps and your pipes are 12 mm I have some push fit 15 mm to 12 mm reducers if you need a couple ;)
terry
Dawn B
Oct 20, 2013
5,299
13,199
South Norfolk
Yes
I've been told it needs a new ceramic cartridge, but without knowing the make it's not that easy.
And anyway, 3p doesn't buy much
Dawn B
Oct 20, 2013
5,299
13,199
South Norfolk
Yes
terry
Would rather fix if poss. as whole bathroom will need to be dismantled to get to pipes
11,932
9,097
Take the taps to bits then and see what you need ;)
terry
Jul 5, 2013
11,731
13,711
If its leaking after you have finished using it and switched it off then I am not sure it is the ceramic cartridge. More likely to be a leaking joint where the flexible shower hose goes into the main body of the tap. When you switch the shower off the flexible hose is full of water and that is when it starts leaking out at the bottom. As I say if you can tell us where it is leaking from then we would know better.
Dawn B
Oct 20, 2013
5,299
13,199
South Norfolk
Yes
It's leaking from the tap, where it swivels
Aug 18, 2014
23,806
133,914
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yep they all do.
Everytime.
They could be Spanish. I've had/have loads.
They either leak within no time of installing or they'll never leak. I think they are a generic & just badged differently for various 'makers'.
If you can get a new insert that's probably the best way to go.
M
Madwife
We had a leaking kitchen tap in the Burstner and it turned out it was the cartridge had gone kaput. Johns Cross sorted it out for us and sure they could help you.
Kath
