Help, I've upset my solar controller
Discussion in 'Tech/Mech General' started by Jandc, Oct 27, 2014.
  1. Jandc
    Jandc Funster
    Oct 31, 2010
    66
    140
    lincolnshire
    Good afternoon you clever folk.
    After spending all morning wiring my 300watt inverter directly to one of our leisure batteries my electrically challenged other half had successfully provided me with the means to use my hot brush, hoorah!!
    However all the lights on the solar controller then began to blink furiously and the van control panel was showing constantly changing voltage in vehicle battery. Disconnected the inverter again and all went back to normal.
    Help and advice would be so much appreciated, I know someone out there has the answer
    janis
  2. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,035
    6,557
    Roobarb land
    Mine did same first disconnect solar panel wires from controler then battery wires from battery
    Wait for a minute
    Conect battery wire and wait for controler to show battery voyage this sets controler to 12 volt
    Then re conect panal wire
    If you don't do it in correct order then control Cannot set its self to correct voltage 12 18 or 24 volt
    • Like it Like it x 1
  3. Jandc
    Jandc Funster
    Oct 31, 2010
    66
    140
    lincolnshire
    Thanks for prompt response
    So if I disconnect the solar panel wires from controller, disconnect batteries, add invertor connector to terminals, reconnect batteries, reconnect solar panels to controller it should be OK?
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,067
    12,416
    Plympton, Devon
    In the absence of any instructions, connect the batteries first as that powers up the electronics in the controller, then the solar panel and then the load. I would connect the inverter last but assuming it is wired directly to the battery terminals I don't think it matters.
  5. Jandc
    Jandc Funster
    Oct 31, 2010
    66
    140
    lincolnshire
    (y) Thanks you wonderful folks, hopefully all sorted now. What a forum!!!
    I assume from other posts I have read that if we keep inverter switched off it will not draw any current from battery, although
    It sure draws it when using hot brush, it will be a two minute hairstyle.
    Janis
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,076
    3,472
    Eastbourne East Sussex
    Depending on the inverter it may still draw a tiny current when switched off. This is because the switch doesn't actually disconnect the 12v from the battery (it is usually a titchy thing that couldn't possibly switch 100amps or so) a bit like leaving a TV on standby.
  7. Jandc
    Jandc Funster
    Oct 31, 2010
    66
    140
    lincolnshire
    Thanks, we.ll see how it goes, may put in remote switch if it is a problem, I assume solar will deal with it
  8. Styx
    Styx Read Only Funster
    May 1, 2010
    572
    2,970
    Buckinghamshire
    You could always save yourself the worry and ask Santa for a Braun (other brands are available)gas cell hot brush (y)
  9. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,717
    On this thread by mistake.............from the thread title I thought you were a Buddhist seeking enlightenment.:nerd:
  10. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,942
    1,961
    Warwickshire
    If the inverter is large enough to run a hot brush, I am surprised it did not come with a remote switch. However, assuming it did not and you want to include one, I think you should use a relay. You might care to read my description of an installation in the Resources section: http://www.motorhomefun.co.uk/forum/resources/install-a-small-inverter.17/
    This installation was for a 150W inverter, but the same principle applies to a larger one.
  11. Jandc
    Jandc Funster
    Oct 31, 2010
    66
    140
    lincolnshire
    Hi, it is the smallest wattage hot brush available rated at 240watt. Like yours Phillip our 300 watt (1000watt surge) inverter was supplied with cigar lighter plug. When plugged into the cab socket with engine running my hot brush worked well, but totally refused to work when plugged into habitation circuit via the cigar socket used for the TV. As you say, due to length and thickness of cable supplying this socket all I got from the inverter was warning lights and alarms!
    So decision made to connect directly to battery. Inverter is mounted to end of settee behind passenger seat, so plug and off switch easily accessible and unit has plenty of ventilation. Seems not to be affecting battery voltage so far. I'll hang onto your excellent and clear instructions for fitting relay and switch Philip and may yet carry out the adaption.
    Have tried the Braun gas option, tongs led to singed curls and the hot brush provided very poor results, I like a hot brush with some "blow" so have the cheapest and lowest wattage from Boots.
    Thanks everyone
    • Like it Like it x 2
