Hab battery change help (1 Viewer)
Busman
1,766
4,332
Wirral
Esterel
A few years
was looking to change my hab batteries before setting off for a few months, thought it was just a case of Swopping like for like then I opened the battery compartment, ahhhhh
help needed on do's and don'ts as don't want to cock this up. Is it just a case of unplugging everything and what must I look out for.
Note the level in pic 2
Thanks in advance
@Techno
17,630
43,340
ignore all the secondary wiring and just take the leads off the batteries. do one at a time, as in replace the left one and reconnect the wires then do the right. far less chance of causing a short.
if you cant get the batteries out without unplugging the relays then take photos to double check it all goes back as it was previously
personally it would annoy me having a rats nest of wires and i would take the extra time to tidy them up. at least with a few cable ties
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Agree with TheBig 1 Take a picture if not sure. For safety reasons remove the negative connections on your batteries first and re-connect last. I see you have a shunt fitted so be aware you may have more than one connection on your battery terminals. Use a bit of coloured tape if you want to be assured your fished set up is identical to the existing set up. You will be fine. Don't forget about the negative connections first, this prevents sparks and fuses being blown.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Agree with above. I would add that it's important to disconnect your negative terminal connections first and re-connect last.
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Going thru the old paperwork for the van it looks like these batteries have been in since July 2010 would you change them, ( I think I should) or top them up. Am I also right in thinking that these would be the "Wet" type.
Ta
andy63
4,672
15,017
south shields
since 1990
Hi dave.. I'll add my two pence worth:D..
Before you star switch off your control panel.. ie kill the hab side of the electrics. .
If you can get to the main negative disconnect that first then the positive. .. disconnect as little as possible ie just the battery terminal connections... it may also pay to tape up the loose ends to insulate them while you are working... just in case there is a feed from the start and your still live..
If you have the time you could tidy up the wiring ...but if all works as is then unless you want to give yourself the extra work maybe best left..:LOL:
if your batteries are wet the caps will be removable... you could just top them up and replace... have you reason to believe they are done... ie not holding any charge when on load..??..
Can't think of much else...replace either existing or new batteries and then switch back on and charge/check everything works...
Good luck..(y)
Andy.
Aug 18, 2014
23,795
133,789
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
If you have 2 batteries & are changing one at a time make sure after you disconnect the negative, That when you disconnect the positive it cannot earth out anywhere as it will still be live due to the second battery.
far better to disconnect both negatives off of each battery & then change them one at a time. & yes as previous take a few photos & with the flash on. If an odd wire comes loose then you should be able to sus where it came from.
Aug 11, 2016
353
1,145
ipswich
Not sure
1 year
You say the batteries were fitted in 2010 according to the paper work but could they have been replaced since then and there is no paper work for them. Seven years seems a long time but as Andy asked have you a reason to doubt their performance, if not I would top the up and carry on until I had some concrete reason they were getting knackered.
