Just open the tap slightly before bed time and by the morning you'll have a nice empty tank !
If done right the water will soak in before it can form a puddle, under cover of darkness no one will no .
Vlad
Just be aware of the foam mountain. Sometimes the bubbles form a little pyramid under the outlet if it runs too slowly
So I have been told
Think about it.........Being quite childlike I still like to melt the foamy bubbles in my bath with a bar of soap ,which got me thinking how could I apply this to the foamy pyramid ?
Try this.......Tie a bit of string from the bath overflow thing, to the appendage in question. Lie back in the bath, bracing your feet under the taps. Then pour a full box of Robin Starch into the water............More of a watery dribble nowadays Toots !
Vlad
I'm surprised that this suggestion is being 'liked' when a new-comer is asking a serious question. This is what gives MH ers a bad name. There is nothing worse than being directed onto a pitch that has a greasy, soggy area attracting flies. I have experienced this a few times when I was using the caravan and is a very selfish attitude.Just open the tap slightly before bed time and by the morning you'll have a nice empty tank !
Vlad
I can get a bucket under my waste tap Kevin, just drop a couple of gallons out and take to black water waste or toilet. Most sites have a drive over waste drain, usually a concrete pad with a drain in the middle, poss water fill point there too.
Why?? What's wrong with a bit of soapy water?? Try following a diesel leaking tractor on a large motorcycle.I'm surprised that this suggestion is being 'liked' when a new-comer is asking a serious question. This is what gives MH ers a bad name.
Just do what @Tootles and @Bertie Bassett do, when you set off just open the drain valve and let it p**s all over the place as you drive along
Lights blue touch paper and steps well back
Ha Ha. Yes we saw someone do that Paul, but seriously do you carry a waste water carrier, my MH is getting a bit full
If done right the water will soak in before it can form a puddle, under cover of darkness no one will no . Vlad
Nothing wrong with that!! Just kick it about till you lose it!!The auzzies use all their house grey on their gardens, as fresh water is valuable. They are much more concientious than us, so I done see a problem with recycling it back to the ground, but round the edges .
Better than the french with their black waste. They seem just to spread it on the ground, away from their vans though. lol
Haha pmsl, when we were tuggers we had a black waste container laid on its side with the pipe going into the top/side, just crack the big bung so it 'leaks' and your fine for a fortnight lol.Get a bucket, put a hole in the bottom of the bottom of it. Never needs emptying.
