- Jan 10, 2013
- 5,958
- 7,354
- Warwick XL PVC
- Still trucking and learning
Me too...I use those round sat nav mounting discs from Halfords, works a treat.
I have a Garmin and only use it occasionally but when I do use it I have this
http://dm0yv73xe8whs.cloudfront.net...b8d27136e95/g/a/garmin_friction_mount_M_4.gif
Other types are available.
They work well on the large dash of A class's, the disc wouldn't work on ours because it carpeted, and it works in the car.
Swivel the screen mount and stick it on the side window.....works for me.
The same as ppj side window works very well and cost nowt
I have one of these and love it!!A friend put a link to this on fb the other day
http://www.cdslotmount.com/
don't know anything about it, just thought it was a smart idea - it's not £2.95 though...
You can but a "Brodit: bracket which fits exactly for each different vehicle base, you then attach the satnav mount to that. I have a Fiat x250 and my mount is fixed at the top of the fresh air vent on the dash, that means my satnav is in easy reach and easy to see. Mine is a 5 inch Garman 3598 but if you had a larger satnav you would probably knock it when using the indicator stalk. Search "Brodit mount" on google to have a look. You can also as previously said in another reply buy, much cheaper ,round adhesive discs to stick on a flat piece of dash if you have one, but much depends your base vehicle
