Gps Mounted On Dashboard - Recommendations??
Discussion in 'Motorhome Accessories' started by The Dude, May 26, 2015.
  1. The Dude
    The Dude Funster
    Jan 10, 2013
    2,433
    2,486
    Near Uttoxeter and Crete
    We've recently changed our motorhome from a C class to an A class and the GPS is now too far away when stuck on the windscreen. Does anyone have a recommendation for a good dashboard holder?
    Thanks.
  2. Southampton
    Southampton Funster Life Member
    Dec 16, 2011
    514
    300
    Hampshire
    • Like it Like it x 2
  3. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    337
    237
    South Essex
  4. Manic
    Manic Funster
    Nov 4, 2011
    1,048
    1,180
    Uk
    • Like it Like it x 1
  5. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    I use the same and have been for years. I use a clip to attach it to speedo cluster so I can see clearly.....
  6. iandsm
    iandsm Funster
    Jan 3, 2008
    1,673
    2,821
    Suffolk
    You can but a "Brodit: bracket which fits exactly for each different vehicle base, you then attach the satnav mount to that. I have a Fiat x250 and my mount is fixed at the top of the fresh air vent on the dash, that means my satnav is in easy reach and easy to see. Mine is a 5 inch Garman 3598 but if you had a larger satnav you would probably knock it when using the indicator stalk. Search "Brodit mount" on google to have a look. You can also as previously said in another reply buy, much cheaper ,round adhesive discs to stick on a flat piece of dash if you have one, but much depends your base vehicle
  7. The Dude
    The Dude Funster
    Jan 10, 2013
    2,433
    2,486
    Thanks for all your responses - I have just ordered the 3M sticky one on ebay - £2.95 with free postage. Too far to drive to Halfords from where we live.
  8. Eeyore
    Eeyore Read Only Funster
    Oct 28, 2010
    370
    414
    I found our TomTom kept falling backwards from the sticky pad so cut a section of foam pipe insulation ( the small diameter stuff) so that the base of the sat nav was held firmly in the slightly enlarged crack in the foam. I then shaved a bit off the base of the foam tube so it was flat and stuck firmly to the sticky pad.
    One year of use and it's not fallen over yet...
  9. Styx
    Styx Read Only Funster
    May 1, 2010
    572
    2,970
    Buckinghamshire
    A friend put a link to this on fb the other day
    http://www.cdslotmount.com/
    don't know anything about it, just thought it was a smart idea - it's not £2.95 though... :frowny:
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,089
    17,759
    YO11 2BD
    Swivel the screen mount and stick it on the side window.....works for me.
  11. berni109
    berni109 Funster
    Sep 10, 2012
    320
    279
    worcester
    Got a cheap Chinese rip off CD slot mount off ebay- about 10 days to arrive. Seems to do what I want holding 7 tablet running sat nav app.
  12. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    733
    4,701
    Chelmsford Essex
  13. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,643
    7,339
    Plymouth
    The same as ppj side window works very well and cost nowt :)
  14. golly
    golly Funster
    Aug 16, 2009
    1,181
    2,126
    Co Durham
  15. The Dude
    The Dude Funster
    Jan 10, 2013
    2,433
    2,486
    Can't do this as hubby is the one who does the driving and therefore needs to see and I am the one who makes the changes to the GPS in transit.
  16. Viennese
    Viennese Funster
    May 21, 2008
    2,433
    2,667
    Oxford
    I have one of these and love it!!
  17. Charlie
    Charlie Funster
    May 16, 2015
    2,536
    3,012
    The problem with those CD slot mounts is they place the Nav unit far to close to the cars Head Unit.
    Most Navigation manufacturers advise against putting the Nav unit anywhere near the cars Head Unit as the strong magnets inside will greatly interfere with the radio signal.
    I mounted our Garmin unit directly over the top of the HU in our Peugeot and it buggered the radio . The reception was woefully poor with much crackling and interference.
    Reading the Garmin book for something unrelated I noticed the warning not to mount close to the HU.... So I got another plastic mount from Halfords moved the Nav and the radio is now fine..
  18. CherryPirate
    CherryPirate Funster
    Sep 4, 2013
    157
    161
    Hants
    I too have always used Brodit mounts. These come in essentially two components:
    1. The dash mount - Made specifically for your vehicle and often comes with a number of different choices where you want it mounted. You can buy an additional mount for any other vehicles you are likely to use with your GPS.
    2. A Holder for your device - This is specific to the item you intend to hold. It could be for a phone, tablet or something else.
    Each holder for each device can be used in any of the vehicles you have a mount so it is a very flexible system. More money initially but when you change vehicles you just buy a different mount.
    I have my navigation on an IPad mounted in a holder with the dash mount in the centre of the vehicle pointing towards the driver. Works well for us.
    The company in the UK who supplies these is DSL developments
    Colin
  19. Ron & Gerri
    Ron & Gerri Funster
    Sep 2, 2014
    1,002
    5,074
    Gloucester
    image.jpg We use one of these as we didn't want to permanently 'stick' anything to our dash. It's a rubber mat and stays by friction, only costs about £4.50 from Fleabay. Just about to order another one for the dash cam as we are so happy with the sat nav one.
    Edit: just ordered another, £4.34 and free delivery!
  20. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    If you have a cup holder on the passenger side of the console as we do (2003 Ducato) buy a tub of These or These from Superdrug. The tub is just the right size to fit the cup holder snugly and the suction mount sticks to the top well. We have tried it with both the Noza Tec and Garmin Camper 760 sat navs and they are both easy for the driver to see and for the passenger to make any changes.
