Glue for plastic petrol tank (1 Viewer)
bill harris
12
Kent
Conversion
Since 2008
Hi there,
Does anyone know of a glue/ adhesive that wil stick two halves of a plastic petrol tank together. On my garden rotavator.
Bill
Aug 18, 2011
12,140
18,005
derbys
AUTOSLEEPER SYMBOL
Repaired a metal tank years ago with a sharpened match stick to stop the flow and then sealed round it with well chewed chewing gum. It lasted years. BUSBY:Smile:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Araldite or any two pack type, glass fibre ribbon but all the surfaces must be very clean
Peter
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Hi there,
Bill
Just trying to work out how your petrol tank came to be in two halves!! ::bigsmile:
B
bill harris
12
Kent
Conversion
Since 2008
The reason the tank in two halves this the way it was made and it was badly leaking when I got it and the joint came apart so now in two pieces.
Bill
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Rinse it out for 24 hrs, then get a big electric soldering iron and "weld" it together.. Then pressure test it to 5 PSI and if any leaks, get a 2 pack adhesive such as araldite and go over the join... OR !! Get a 5 litre plastic spare fuel can and mount as appropriate... Good luck, but be careful !! :thumb:
TheBig1
17,630
43,323
the glue will cost nearly as much as buying a second hand replacement. if you must try a repair, 2 part araldite is the best with petrol or try heat welding with a hot air gun and plastic welding rod, the same as used to repair plastic bumpers etc but prove its water tight before use
