Genny (2 Viewers)
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
When running off a genny do you connect into van 240v through ehu lead or 12v straight to battery bank?
Reason i ask is that i have read that some people have blown there on board charger so now go through a stand alone battery charger to by-pass van control unit.
Tony
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
When running off a genny [HI]do you connect into van 240v through ehu lead[/HI] or 12v straight to battery bank?
Tony
Yes, exactly that.
chatter
3,689
937
cheshire
5th wheel
maybe they were using the wrong type of genny, or too small a genny to cope with what they were trying to run in the van. We have never had a problem with ours so far and just connect to it as if it was a ehu point.
Just had a thought they might of connected it all up before starting the genny which could cause problems (mega spikes power wise) - you are supposed to start genny and let it get on a even keel before connecting your ehu lead.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I plug direct into the EHU inlet point. But I have a Honda EU10i which produces a very clean output. I would only do it with a decent pure sine wave generator, not with a cheap and cheerful one.
Schaudt Electroblocs (EBLs) are sensitive to voltage spikes; they are used in several German vans. I also have a surge protector at the point where the 230V cable enters the EBL for added security.
If you can / are happy to connect via the 230V inlet, the charge rate will be much higher than if you connect 12V direct to the batteries. E.g. the 12V output from my Honda is rated at 8 amps; the maximum output from the EBL is 18 amps.
So did I, it died anyway. Result of a thunder storm on hook-up here.
JeanLuc
3,304
2,199
Warwickshire
Good point Brian - if caught in a thunderstorm, it's worth disconnecting the hook-up cable (assuming you are with the van when the action kicks off).
I admit to having a fairly cheap in-line surge protector. I don't know how much better the dedicated Schaudt OVP 01 protector is - hopefully pretty good considering the price.
aba
2,775
1,112
yorkshire
dec 2009
save the money and buy a bigger battery bank and some solar panels and if this weather keeps up like it has for the last few weeks a wind turbine then you wont need hook up.
or a genny
JeanLuc
3,304
2,199
Warwickshire
or a genny
I rarely use mains hookup. Got two batteries, got a 135W panel, got a genny for when the sun don't shine; NOT got a turbine, but I often get wind!
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::
jaygee
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Thanks for replys to date
van is new to us so making improvments for a skiing hol
I have fitted 2x110 amp leisure batts with space for another if required,not sure if van alternator will take another at this stage although i could fit a split charge relay between 2nd and 3rd battery
Also in the process of fitting leds
Could be away for 2 weeks or more without ehu so genny is a must
Have not yet fitted solal panels as im still looking into their performance especially as it could be cloudy for the time we are away (hopefully not)
The genny is a 1998 honda ex1000 and van transformer is Schaudt 99
In previous van i have hooked up genny to ehu lead with no problems but have heard that with later vans there could be problems like spiking the ecb
Maybe me just over concerned but when temp below freezing i need power
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
TMI??::bigsmile:
Or perhaps a neighbourly warning.
John
43,331
49,480
wont be any problems if you use an inverter generator.....Honda etc.
exactly the same electrical characteristics as a 230v mains supply
haganap
12,762
26,460
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
will respond by PM later,,
But Genny will be fine, honda's nice and clean, I always start then plug in for extra security, as for a bigger battery bank and a couple of solar panels? No chance for a skiing holiday, its genny all the way.:thumb:
2,338
10,133
this is the older style genny that has an AC alternator producing the 230v AC and runs at a constant speed irrespective of load.. IIRC it has frequency meter and a screw to adjust the engine speed to give 50hz ?
A secondary winding provides 12VAC which is then rectified to provide 12VDC
In some respects I think it is better than the newer ones with inverter technology , in as much as it is simpler and more reliable (less things to go wrong) and it gives a very clean sine wave.. but on the downside, irrespective of load it runs at a constant speed.. so uses more fuel.
Provided you let it settle down before connecting the EHU there should be no problem.. however, if you plug in a heavy load it will tend to slow down momentarily then maybe hunt as it tries to re-establish a constant speed.. this could cause a voltage spike which could damage sensitive electronics ..
To be frank, it is better suited for power tools and inductive loads rather than powering electronics.. but used with care it should be fine.. If you ever sell it keep me in mind... :winky:
