Gas Tins (1 Viewer)
These i think are screw in
Broken Link Removed
And these are not
Broken Link Removed
Going to buy a cheap camp stove but unsure what is best/available in Euro land just in case i run out of gas. Anyone any idea?
I dont want to carry to many tins.
DBK
18,025
48,095
Plympton, Devon
PVC, Murvi Morocco
My guess is the first, being campingaz should be easier to replace, the disposable campingaz cartridges now having a sort of screw connector, the older ones being pierced. The second might have the Coleman type screw connector which I think may be harder to find.
Cheers DBK ill just get the campingaz stove. Its only something like £3 difference in price and the screw in gas i have see sold in the likes of BM stores and Aldi for the weed burners.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Broken Link Removed
And these are not
Broken Link Removed
I would be pretty sure that they are both the same, we have the little campingaz stove and anything with that same style fits OK. Good availability as well as I picked some more up on our travels but cant remember where.
Martin
Martin
Nah Martin. The 2nd one (Hi Gear) its a little lever you pull in the stove what pulls the gas canister in to either pierce it or push the end open. Ill have a closer look tomorrow when i go to the shop.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Push in
Have the single burner stove usung those bottles in them as above place bottle in lift lever to engage turn the dial (pieso)? Ignition
Shop around for better deal on bottle pound stretchers £4.99 x 4
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Thats how the Campingaz stove works, thats what we have, you have to disconnect the canister from the stove when it goes in its case or I should say if you dont it pushes the lever up when you pack it in the case.
Martin
Martin
Bugger. I was under the impression it was screw top. :oops: Cool but ill still go for the Campingaz one as its a slightly larger tin
Minxy
32,656
66,563
E Yorks
Carthago Compactline
They are usually £3.99 for 4 in B&M stores, paying more than that is 'expensive', you can get them abroad but they can be a fair bit more expensive than the UK ones, eg up to €3 for just one can!
Just make sure when you get your stove that you don't put a large frying pan on that overhangs the gas compartment as this can cause the gas canister to overheat apparently.
Aye a guy was saying in the shop. There was no Campingaz ones left to had to but the Hi-Gear anyway what was a bummer as i was in B&M some 20 minutes earlier and could have got a stove from them as £2 cheaper.
