Gas problems (2 Viewers)
Dec 18, 2011
747
509
Hull
Autotrail 634
When we arrived at Peterborough the other week,I realised I had greatly reduced pressure on all my gas appliances,to the extent the fire wouldn't even light.Next morning,without any effort on my part,it was all working again!This weekend we are at York and the same thing happened again.As we are going to France in 2 weeks I really need to sort it.My question is,can it be anything other than the regulator?My set up is that I have a cylinder fitted under the fan and fill up at the pumps.It was all fitted by Autogas 2000 in Thirsk but unfortunately they are now closed until Tuesday.I was going to drive the short journey to their workshop from here in Yorkbut will struggle to get there before we set off for France.If it's just the regulator I can buy one and get it sorted.Any advice appreciated.
May 1, 2015
580
430
Caerphilly
Rapido C86 Auto
Since 2014
Are you using Butane or Propane, if its Butane that could be your problem as it doesn't work at low temperatures - below 4 degrees I think.
Maybe night time temp was below 4 degrees rising above that in the morning.
Patrick
SandraL
1,373
985
Somerset
Hymer b694sl
Where did you last fill up. If UK it will have been 100% propane, if Spain then perhaps 30% propane and 70% butane leading to symptoms you have experienced.
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
Run your gas down it's a bit warmer today then fill up think you will find it will be OK when you get sum propane in the system
I would top up firs to see if that fixes it first before buying a new regator
Or warm up the tank with the hare drier
Bill
Camper634
Dec 18, 2011
747
509
Hull
Autotrail 634
Its propane,same stuff I have always used..Never had problems before even in freezing conditions.Could just be a bad batch I suppose.I think at around £30 I will replace the regulator just in case.Its the fact it comes and goes that puzzles me though
Jun 14, 2014
1,453
3,105
Coventry
IH N680CFL
Since2014
Bill
Source of ignition heating a gas tank. :Eeek: Are you sure. Although standing a large rabbit like animal next to the gas tank won't warm it up. Unless it rubs it hard I suppose:whistle:
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
As long as there is no leeks the I don't se a problem but you could always just wate for summer :rofl: advice on her is given freely and withe the best intentions Bill
Reactions: Al1
2,347
10,196
you don't get bad batches of propane, certainly not in the UK
change the regulator..
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
There was an issue with regulators a few years back, they where apparently "gumming up" with a residue that had some connection with the material the hoses where manufactured from. It was supposed to be cured by a change to the (hose) materials. Question?. how old are your hoses?.
You will probably have to change the Regulator anyway, as they apparently dont clean.
Pete
icantremember
8,335
17,549
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Pete
I assume That as it is an underslung tank there will be no rubber hoses involved.
Best to speak with Chris at Autogas2000.
PeteH
6,853
9,030
Rapido, 999M.
Was that the filler hoses or supply from the tanks to the rv?
The filler was mounted direct to the tank(s) one either side. The high pressure hose connected the Tank outlet from the Regulator to the Steel pipework, which then connected to the Copper used inside the R-V. There was another section of HP hose which connected the Pipework for the (separate) Tank for the Generator to the Generator, It seems complex I would agree, and the only reason we came come up with was to isolate the various items from vibration!, and might have had to do with not using as much copper pipe?. That was 1980`s American style!.
It was a similar system, but using only one tank on the Odessa. But the Winnebago had copper pipe throughout.
Pete
Sep 26, 2013
4,172
5,159
Market Rasen
Since 2003
On my Autogas tank the regulator is fitted directly to the tank so if yours is I'm not sure if you can remove it with lpg in the tank.
Camper634
Dec 18, 2011
747
509
Hull
Autotrail 634
There is a gate valve on the tank which does allow for the removal of the regulator without draining the tank.On the original regulator the fitting into the tank is bigger than 8mm.I hand an 8mm spare regulator but can I get an adaptor to reduce the tank outlet to 8mm?
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Is any of the pipework made of rubber hose? One of the problems of gloopy residue blocking the pipes was due to a reaction with rubber hoses. Flexible stainless steel piping is recommended as a replacement.
Camper634
Dec 18, 2011
747
509
Hull
Autotrail 634
No it's all solid copper pipe.I see you can now buy filters to fit inline between the tank and the regulator.More expense
