Gas low help please (1 Viewer)
AndyPandy
97
55
Hartlepool
Since 2012
Hi folks,
So, we're out of gas and its time to go fill the Gaslow bottles, but how do I do it?
We have 2 large bottles and between them is a regulator type device which can be turned to switch from one bottle to the other.
Which position should this regulator be in when filling?
Does the gas balance out between the bottles?
Should the valves be open on the bottles?
Many thanks for any help to a newbie,
Andy
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
Hi folks,
Which position should this regulator be in when filling?does not matter:Smile:
Does the gas balance out between the bottles?yes:Smile:
Should the valves be open on the bottles?no! valves should be closed when filling:Smile:
Andy
see above:thumb:
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
I always fill with the bottles turned off as you drive with them off .
So long sa the two bottles are conected to the filler they both fill together.
I dont know the system en the UK but here you connect thefiller then hold the button in till it stops.
You cant overfill.
I fitted Gaslow from the UK. Had no problem with them.
I Have now transfered them to my new Motorhome which can travel with the gas on.
So i never thought about filling up , I thinki will still turn them off tofill up
Hope this helps
Mel
407
22,220
Portugal
Don’t own one.
Since 2006(1986 VW T25)
This just confirms what a great site this is . Our new motorhome is fitted with gaslow and this is one problem I was dreading, thanks all with your great advice and links. :thumb::thumb::thumb:
GJH
29,450
38,827
None, now sold
2006 to 2022
And be totally amazed just how long it does take to fill. Like forever.
At the closest LPG garage to us the tank is quite some distance from the pump so you have to wait for the cashier to authorise the pump (can take a while at busy times) and then wait again for the gas to actually reach the pump. Well worth it for the saving though :Smile:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if you have 2 11kg bottles you shouldn't get more than 44 litres in expect around 40 ish if they are both empty.
the secret with gaslow is every couple of weeks as you drive past the filling station just top em up provided you have used them of course
3,204
33,557
SW Northumberland
Hymer B 588 DL
Since September 2010
Our first fill a few weeks ago, waited a short while near the pump till a Discovery came in to fuel up. Jumped out and asked If I could watch, the guy was very helpful and hung around to make sure I filled up correctly. :thumb::thumb:
GJH
29,450
38,827
None, now sold
2006 to 2022
I had to ask for help the very first time (just after the first Alugas cylinder was fitted) as the instructions on the machine were a bit unclear. Since then I tend to have the instructions provided by Dave Newell to hand.
Yesterday (for the first time ever) there was a member of staff on hand at our local station (just changed from Total to Shell). He fitted the gun to the filler point and made sure I was comfortable with the rest of the procedure.
961
639
Rugby UK
C Class RS
Just be prepared for the whoosh of gas as you disconnect. It's not that bad but will make you jump if you're not expecting it. ::bigsmile:
I have topped up my underslung tank up 4 times now and I still jump out of my skin when the "whoosh " happens !! getting to a pump on the left side with a big euro box is sometimes challenging so I think I pay a bit too much for the easy option on the motorway, much better than fetching bottles though:thumb:
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
First time filling in France I attached the right adaptor, connected the pump and lent on the button. After 10 minutes of nothing happening the attendant appeared and made plain to me that the button I was pressing was the emergency stop which he then unlocked with a key. Pressing the correct button made all the difference:roflmto:
Camdoon
1,531
2,808
UK
Adria Matrix Supreme
Broke my cherry today and had to ask for help.
There were barriers either side of the pumps which stopped the nozzle easily sitting in its holder, stopping both the pumps from working. The attendant manually held the triggers in the pumps to reset each of them.
Once that was overcome a relatively straightforward procedure although there was no one waiting so less hassle.
Now I have to work out which adaptor fits for which country (not today though)!
JJ
Mágica
May 1, 2008
19,259
48,048
Burstner Privilege T
over 50 years
I did exactly the same thing down in the Algarve last year...
Not our fault... different layout on the pumps... :whatthe:
JJ :Cool:
jennyp19
75
33
Sunny Scunny
about 10 yrs
We just filled ours for the first time today - gave us a bit of a shock - :whatthe: - I hadn't read this post first.
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
I'm with Brian, takes what seems like ages, then I say to Pete after Were they empty? and he says no, only took 6L or something! :roflmto:
Actually - no I don't cos we're anal and record stuff like that ..... ::bigsmile:
AndyPandy
AndyPandy
97
55
Hartlepool
Since 2012
Thank you all
Guys,
Thanks for all the help on this you have given me!
I was getting in a bit of a flap about this, but armed with hints n tips from you, I managed no bother.
We are now, once again, cooking on gas :)
Thanks again,
Andy
#motorhomefunrulesok
