gas it (2 Viewers)
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
anybody know what size hole needs to be cut in to the body work for an external gas it fill point any help appreciated
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
I think it is 70mm but should be on the instructions that you got with it, or on the website.
Aug 28, 2013
64
83
luton
Elddis Acardo 125
Gas-it sell the correct size and as Dux said fitting instruction are on their web site.
Nov 4, 2011
5,944
39,079
Uk
If you don't want to cut a 70 mm hole, you could use a jic filling point which only need a 30 mm hole.
R
Robert Clark
I'm having GasIt fitted this week and couldn't find any fitting instructions on their website.
Could anyone post a link please?
Regards
Robert
R
Robert Clark
That's what I thought
Had downloaded before
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
thanks for all your replys found the gaslow instructions one question is it ok to put external fill point going into gas locker instructions say put it low down but seems to me it will be hard work bending down to the side skirt aprrox 1ft off the floor ,seems easier to have it higher up and go straight into gas locker as it is vented so any lost gas will escape through the floor, what height have you put your filler at ?
Apr 23, 2014
672
861
Spain ??
Ice cream van
Since 2011
Yeah no problem if you want to fit into gas locker, I fitted mine in the garage see attached pics works fine (y)
Wickolad
490
542
Wickersley
I fitted a bracket on inside of gas locker for mounting the fitting. Thereby doing away with cutting a hole in the MH panel. Also, if I decide to swap the MH, I can remove the system and refit in the new vehicle.
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
horshamjack how high is your fill point from the floor just it looks quite high is it a good height for the gas gun ,and can you tell me how is the body off the fill point secured to the side off your motorhome pic off back would be good as i cnt see how you secure the bacl as my side walls are about 400mm thick and outer partoff fill point will not connect to the front part without very long screws
jonandshell
5,476
8,299
Not got one!
Only an observation, but putting the fill pipe through the garage is not good practice.
High pressure hoses should be situated externally to the vehicle interior unless routed through externally vented ducting.
This is an LPGA standard.
Abacist
3,752
10,845
Devon
N & B Arto 88F Tag
since 2013
Looks more like a gas locker than a garage to me!
