Gas hob and water. (2 Viewers)
ShiftZZ
21,383
84,576
Dark Side of the Moon
The Rapido, has a gas hob similar to this,
Broken Link Removed
And some water has accidentally been poured onto it..
I have removed the top cover of the burner, that only exposed the aluminum burner which has the ignition. Can I remove this without messing with the ignition?
Thoughts/ Suggestions
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Sorry,don't know answer-but am wondering what has the water done that necessitates stripping it all down-water will dry I would have thought.
D
Deleted member 29692
Broken Link Removed
It won't do any harm. Just soak out the worst of it with kitchen roll or something then reassemble and light the burner. It might burn a bit orange for a while until the residual water has gone. Then take it to bits again and clean the off the black mess that will be left over.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
A bit of water won't make a jot of difference. Are you saying it stopped it lighting?
Jim
Ringleader
Jul 19, 2007
36,420
130,907
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I've stripped the one in our Hymer a few times as we had to remove the hob to get at the fridge serviced (long story) But what a pain. I'd only strip it down if you have a real problem, we've had saucepans boil over before without any problems.
Jun 29, 2015
3,477
57,415
Southampton
caravan (for now)
on and off since 1984
Hobs are designed to cope with spillage, let it dry out, make sure the electricity is off. Should be okay by tomorrow.
ShiftZZ
ShiftZZ
21,383
84,576
Have you a picture of yours :LOL: I'll bet it's not that sparkly :ROFLMAO:
If you need a new one I have one bookmarked at £192 cheapest on web (y)
What makes you jump to that unqualified and totally begnin conclusion.
Anyhow I have fixed it and will be vacuuming the last jets on Thursday. The insult. :mad:
Shrimp
May 27, 2015
3,986
33,438
Bedfordshire, UK
Hymer B584
Long time
Our Hymer has a plughole in the hob layout, think it's intended to be used as a drainer!
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
My otherwise identical hob has a sink drain and plug fitted (as standard!) so it can be used as a draining board. It gets very, very, wet in use.
GJH
29,450
38,827
None, now sold
2006 to 2022
Our hob is the same as pictured in the OP. Being in a Burstner, though, the design is such that one doesn't pour water into it :whistle::LOL:;)
