Gas - 16 litre conundrum (4 Viewers)
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Now this puzzled me at the time, and with torrential rain outside keeping me confined my brain is still niggling away at the matter. :RollEyes:
After Eddie's VanBitz sorted out my leaking filler hose yesterday, they filled up the bottles with LPG for me. Now both bottles are 11kg and both gauges were showing right down in the red, which tallied with my recent gas usage. I was therefore expecting a fill of around 35-40 litres. However the fill was only 16 litres - less than half of what I was expecting. I queried this but was told that they had filled till the automatic cut-off operated - and I have no reason to doubt them. :Smile:
Both bottle-neck gauges were showing hard against the green sector after the fill, although after the drive back one (or possibly both of them, it's difficult to be sure with those gauges) seems to have moved slightly away from that position. I have checked the level with the inline Gaslow gauge (gas in use) and it stays full green. But from what I remember of using that gauge before, it only moves off green when the gas is almost gone anyway.
So now I'm wondering if the problem with the filler hose leaking has resulted in the (possible) early operation of the automatic cut-off, in one or maybe both bottles? Could air maybe have been sucked into the bottles - would that do it? I've tried ringing Eddie to ask but just get the answerphone. Still, it is the weekend and he's allowed some time off. :Smile:
So does anyone have any idea what might be going on here? :Confused:
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Hi Maz, I don't know if the following is correct or not, but when I questioned our dealer about the Gaslow gauges I was told that they show the gas pressure and not the amount of liquified gas in the bottle.
Brisey.
haganap
12,762
26,460
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Maybe simply they were not empty when they were filled?
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Brisey.
Now I thought it was the opposite and there is a float sitting in the liquid gas that drops down as the amount of gas left reduces (after the initial 50% - when it stays full green regardless of whether it's 50% or 100% full). :Confused:
haganap
12,762
26,460
planet earth
The only way I've ever managed accuracy with a gas gauge is to ignore it. Maybe use all your gas till empty then refill and see if that cures it...
The summers here now so you won't get cold :winky:
Ad salad tastes good:thumb:
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I've been thinking about that - but in that case both gauges would have had to be reading wrong. If it's a float sitting in liquid, I don't understand how it can drop down lower than the actual gas level.
Also I'd been using quite a bit of gas for my one night out wild camping every three weeks from Ferry Meadows - space and water heating in sub-zero temperatures. As well as my albeit limited gas use (mainly for water heating but a bit of space heating too) when I was parked up in High Wycombe for 3 days with a bottle initially indicating around 30% left, so I had to make it last as I couldn't refill at that point. In other words, based on my usage I'd certainly expected to have used more than 16 litres.
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I filled my gaslow single from empty on gauge and expected 20 litres and only got 15 litres in I think the gauge tell lies
Just been reading through the Gaslow booklet (yet again) and according to that, in the red indicates 18% or less remaining. So if you still had 18% in an 11kg bottle, then the top up could well fall short by around 3.5 litres on 20 litres so that's not too far out.
On that basis, if both my bottles were at 18% full when filling took place that would add around 7 litres to the 16 that went in. So 23 litres out of an expected 40 litres is still only about 58% of what it should be.
14,741
76,046
Mags, I knocked the meter off my cylinder. They appear to be magnetically coupled and by moving the meter a couple of mm each way when half empty I can make it read either almost full or almost empty.
They are a total waste of space. In winter I work on the basis of 1 cylinder lasts 1 week. I vary in how much I can get in on the fill day sometimes its only 14l other times almost 20l but in each case the meter reads empty.... I ran the cylinder to empty on the last fill and it lasted 10 days of which 2 days were on empty.:Doh:
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Yes, I know the gauges are not highly accurate but I have never found them a 'total waste of space' - especially as they take up very little space anyway. :winky:
I flick them with a fingernail to check they are not stuck and on filling I can usually estimate what the cost to fill will be within about ÂŁ1. I fully understand about slight variations in fill each time.
As mentioned earlier, the gauge is supposed to show red when 18% or less remains in the bottle. Your running '10 days of which 2 days were on empty' actually confirms this rather than refutes it. :Smile:
The question I am trying (and failing) to get an answer to is whether the recent problem with the filling hose could have caused early operation of the automatic cut-off. :wub:
Feb 27, 2011
14,741
76,046
[HI]The question I am trying (and failing) to get an answer to is whether the recent problem with the filling hose could have caused early operation of the automatic cut-off[/HI]. :wub:
No :whistle:
Feb 27, 2011
14,741
76,046
The point I was trying to make was that they are worse than the specs suggest due to the fact they are not physically attached to the bottles just clipped around the neck and then magnetically coupled... If you have been able to judge anything by them previously I think that was more luck than the quality of the gauge.
11,842
14,071
Although I have gauges on my Alugas, I don't put too much faith in them. I always just have one bottle turned on and the other off, that way I know if I do run out of gas on one bottle then I've still got a full one. Rather like the gaslow ones, they read full until half empty, then go down quite quickly.
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Yes, I do the same thing - one bottle on, one bottle off. :Smile:
And I fully agree with you that the gauges stay reading full until the bottle is half empty and then they start to move.
But what I don't understand is how two 11kg bottles whose gauges have followed a normal progression downwards until both are in the red can only accept a fill of 16 litres. Even if we allow for quite a bit of inaccuracy in the 18% in the red zone, say it's 25%, and assume that the needle has only just entered the red zone so that there actually is 25% remaining in each bottle - the total fill should still be around 30 litres. That's about twice as much as they actually took!
If I remember correctly they warn you that the float is at the top of the tank so shows empty from about 50%. Just a rough guide really.
We have "Brisey's" pressure guage, also just rough guide.
If you want accurate you need and ultrasonic gas gauge.
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
I agree beside eddie will have checked them out from a safety issue
I just use it as a reminder to fill if its near red fill it up
I have never filled up with gauge showing red and put same amount in twice anything from 12 to 18 litres
it's doesn't make sense at all
So I have stopped worrying
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Here is the Gaslow guide with a good visual explanation of how the contents gauge works:
The gauge does not show empty from about 50%. It only starts to move away from 'full' at around 50% and then drops down according to usage.
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Ok - I give up. It's like banging your head against the proverbial brick wall. :RollEyes:
I am not worried about the accuracy of the gauges. I know from my own experience what they can tell me and roughly how accurate they are. I also know from my usage of the space and water heating since the last fill up that I would expect the bottles to be nearly empty. The gauges happen to confirm that usage.
The automatic cut-off works - there is no safety issue with that. I just feel that it must have operated too early - for whatever reason. Maybe not connected with the leaking filler hose, maybe some other reason.
A total fill of just 16 litres when you are expecting around 40 litres is not normal.
jb0371old
465
408
Autotrail
1 year
empty 11kg gas it bottle took around 20 litres ish to fill from new the other week, went empty and then took 16 litres to fill up the other day, so seems about right to me.
I could go on about gauges if you want but I read the original post and he aint bothered about the gauge:winky:
Armytwowheels
6,475
14,879
Market Harborough
Carthago S Plus - Iveco
Since 2011
This gauge looks interesting Hilldweller, have you been using one? I like the idea of not having to weigh the bottles and do the sums.
23,836
72,506
www.motorcaravaning.co.uk...
I am at a loss as to WHY or what they base the following statement on :
** Neither unit will work on plastic bottles[HI] nor on any bottle or tank with built-in gauges, no big deal there though, why would you need another gauge for those? [/HI] Any other internal hardware (rare) would also interfere with the ultrasound. Please Note that the fairly common Calor Lite, Patio Gas and BP Light are not 'standard' having internal gauge mechanisms or plastic bodies. Also the UK 'dumpy' cylinders of less than 5Kgs are not suitable. Works just great on my standard Calor bottles though!
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I am talking about a two bottle system, not one, hence the expectation of around 40 litres fill in total not 20. If the system had taken 32 litres I wouldn't have queried it. :RollEyes:
32,661
66,574
Well I understand you perfectly Maz ... ::bigsmile:
  • You have 2 x 11kg bottles
  • They were both supposedly empty according to the gauges and your usage estimate
  • You expected to get around 30-32 litres of gas in them both (15-16 litres in each)
  • You actually only managed to put 16 litres of gas in them both
So what you want to know is:
Why didn't the expected amount of around 30-32 litres go in to what appeared to be 2 empty bottles?
  • I wonder if one of the gauges had stuck and the bottle wasn't totally empty
  • or you over-estimated your gas usage?
The only way to tell is to use the gas and see what happens - why not turn off one of your bottles totally and use just one then as soon as it runs out top it up immediately (within reason) without turning on the other one - that way you'll know for sure what goes into the empty one. Then leave it turned off and use the gas from the other bottle only and when it runs out top it up to immediately to see how much goes in that without using any gas from the 'turned off' bottle. If you are able to top them up to what you believe they should take, then the bottles are not at fault and it would appear to be as I've suggested above. :Smile:
maz
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Thank heavens that at last someone gets the point - and, of course, it takes a woman to do so! :thumb:
Yes, I'd already come to the conclusion that I'll have to completely empty and refill each bottle in turn, otherwise I'll not know which bottle is playing up. Bit of a pain as it dictates when I have to head off and find a filling station instead of just keeping topped up as and when suits.
I was actually expecting nearer 40 litres to go in than 30, but would have settled for 32 if that had been the cut-off point.
I really don't think that either of the gauges had stuck as I flick them with a fingernail everytime I look at them, and they had been dropping down the scale pretty much in line with how I had been using the gas. With living in the van, I have a pretty good feel for how much gas I use. :Smile:
Of course the third possibility is that the automatic cut-off actually did operate too soon. From scouring the web I have found that this isn't unheard of, although it is uncommon. But I haven't been able to find out what actually causes it to do so. The solution given was that the bottles were returned to Gaslow who confirmed there was a problem and swapped the bottles for new ones.
peejay
34
25
South Cheshire
WildAx
Started Nov '09
gas mystery
I have a built in 20lt L P G tank, it will only fill to 18lt to full.
It has a 4 indicator light indicating the amount of gas left. Whilst on holiday the week before Easter in Christchurch. Dorset, it was indicating half full, 2 lights on, after 3 Days it was on red, nearly empty. No way had I used that emount of gas in 3 days. I could not understand this " gas loss", As soon as I got home I went and filled up, but only got 14.5 lts. Now I realise my light indicators are only indicators and not accurate gauges.
Before I left for the holiday the indicator was registrating over 2 lights, ie, the third light coming on accasionally.
I put this discrepancy down to the freezing weather and the L P G not " gassing up " am I correct do you think?
Ppjay
